Non start - 1979 125cr - help please
Discussion in 'Vintage/Left Kickers' started by Ruairi, Jul 7, 2019.
  1. hhdwtmtw He who dies with the most toys wins...
    Melbourne, Australia
    '14 TE300, '11 TE449, '10 TE250
    Royal Enfield Continental GT 650
    Engines need fuel, compression, spark and the correct ignition timing to run. Assuming the engine ran ok prior to the rebuild then something is missing or out of range in 1 of those 4 variables. Eliminate each variable one at a time.
    Fuel. The engine runs if you squirt gas in the plug hole so this would indicate the timing, compression and spark are good.
    Compression, see point 1. It ran however do a compression and leak down test.
    Spark. See point 1 again. It ran so spark and timing should be ok. Check your flywheel woodruff key is intact.
    It sounds like a fuel/carb issue.
  2. BadMotoFo Husqvarna
    Bay Area, CA
    1974 250CR, 1981 430CR, 1986 400WR
    Yamaha TY175, Yamaha TY250
  3. Dave-cr125 Husqvarna
    Gloucestershire UK
    Cr125 1972 and 1976
    Triumph t150 1972
    If you haven't fixed this already check the woodruff key hasn't snapped causing the ignition timing to go out. Happened to me.
  4. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    If you are getting a backfire through the carb suggests you might have a problem with the reeds, broken or not shutting properly?
