oil in airbox? 630 sms
Discussion in '610/630' started by bpowa, Nov 20, 2011.
  1. SM Flyer Husqvarna
    NW Illinois
    SMS 630
    Thanks rdtcu , I'll do a reroute on the breather hose .
  2. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    The only time I get engine oil out of that breather hose is when I drop my bike on the right side while it's running.
  3. Coffee CH Owner
    I changed the title from 'ion' to 'oil' which is what I think you meant to type :)
  4. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    That is a lot of oil and not normal. Is it possible for leaking piston rings to pressurize the crankcase and blow oil out the breather? I have never encountered this but you get a similar situation with a blown headgasket which pressurizes the cooling system and forces the coolant out. I suppose with rings leaking that much the bike would be burning oil. Other than that it almost has to be overfilled oil. I have the same bike, same year and I get NO oil out of mine. I like to run my oil level a touch high too, right at the top of the sight glass when vertical. Cam.
  5. RDTCU Husqvarna
    '11 630SMS
    Wheelies, drops and high RPM's seem to be the major culprits, regardless of oil level.
    I did notice more oil out of the airbox running Rotella T6 than the Castrol 4T race syn that I'm running now, possibly because the Rotella seemed to foam more.
  6. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    What about a plugged up reed valve? Isn't that thing supposed to vent crankcase pressure?
  7. RDTCU Husqvarna
    '11 630SMS
    As far as I know, there isn't a reed valve, and the valve cover vents straight to the airbox. The big issue is that it's not like an inline 4 where the crankcase pressure is balanced, the crankcase sees huge pulses because there's only a single cyclinder.
  8. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    There is a reed valve. It is surrounded by the cam chain down by the crankshaft. Reed valve damage is common with a cam chain that is too worn.
  9. Roma Husqvarna
    610 sm => 630 sms
    stunt f4i, monster s2r 1000
    Hi everybody ! Just had the same problem with my 630. That began after 5000km service, lots of oil through the breather (to airbox) , but only while doin' wheelies. I've done high and long wheelies before and there was no such a problem. Dealer now has no ideas about it so I'll try to lower the oil level. Have no other ideas.
  10. RDTCU Husqvarna
    '11 630SMS
    If they put in more than 2qt, that would do it.
  11. Roma Husqvarna
    610 sm => 630 sms
    I don't remember about that breathing hose on 610, but I've put much more oil in it and had lots of high and long wheelies without a leak.
    Hope the dealer hasn't disassembled the bike )) Will try tomorrow to lower the oil level
  12. RaduTango Husqvarna
    2011 SMS 630
    Hi guys.
    I'm having the same issue with the oil in the airbox, and don't know what to do. I rode the bike at full throttle in or 5 h gear for 5 minutes or so and oil is coming out. Normally I would think it's something related to the engine, as in pressure escaping around the rings into the engine and pushing the oil out the breather hose. This would be expected on a worn out engine, but mine has 8000 km. And I remember once when the bike had only 2000 km and I dropped it quickly, was only in first gear but I hit an oil patch in the parking lot, the bike was on the ground for seconds only and it still dripped a lot from the airbox. There might be an issue somewhere, I just don't know where to look.
  13. RDTCU Husqvarna
    '11 630SMS
    If the bike is on the right side, it's going to puke oil everywhere, as the valve cover vent is on the right side. Even worse if the bike is still running.
    What oil were you running? Did it foam at all? How high was your oil level in the sight glass?
