Long time heavy equipment/truck mechanic here. Keep in mind that one of the main requirements for tractor transmission fluid and ATF is that they must flow through some really small passages/orifices to operate the shift functions on those transmissions. If the fluid won't flow properly through the valves, particularly when cold, then the transmission won't shift or engage clutches properly. That is the reason those oils are such light viscosities.
In equipment with wet brakes in drive axles, where the fluid doesn't operate a shift function, you'll almost always find spec'd something like an 80/90 standard gear oil. If its just a gear box or drive axle without a clutch pack such as wet brakes, you'll almost always find a heavier oil like a SAE 140. If it's an extreme load or temperature application, heavy synthetic is often recommended, but without clutches in my experience.
My observation is that bike transmissions are most like the drive axle with wet brakes so all my Husky's from 1970 CR400 with it's little bitty clutch up to the 1983 CR500 get 80/90. I fiddle with the clutch until it works properly and have always managed to get good results, within reason, they're old machines after all. Just my opinion, your results may vary.
)Would the Spectro 'Clutch Saver' 10W30 be OK for older Huskys? I can get locally.SPECTRO golden gear 80wt and nothing else. been using it for 20+years with NO problems.
