One hole too many
Discussion in 'Vintage/Left Kickers' started by Brad-in-STL, Feb 24, 2017.
  1. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    The link for this is broken in Tech so you can get the 1986 2 stroke Engine manual from http://www.hva-factory.com/catalogue
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    almost uses the case...but what is important is the relative position of the pawl at rest. 1 spline to far and it causes a nasty back grab when the motor stops. I assume its when it back rotates. its ugly.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
  4. 2premo Husqvarna
    Northern NV
    that is an odd gear number so you can't measure straight across
    what is the ID to OD dimension
  5. Brad-in-STL Husqvarna
    Greater St Louis Area
    '80 390 WR
    '79 XR185, '81CR125, '07 Ducati ST3
    If I'm measuring right (ID to end of tooth?) it's 9.08 mm. If that's not what you're asking, just let me know and I'll try again.
  6. Brad-in-STL Husqvarna
    '80 390 WR
    Well what I'm seeing on mine, is with the kicker shaft in it's "home" position the pawl is held in against the spring holder. See below: Look right?
  7. 2premo Husqvarna
    Northern NV
    I got 9.19 on this one so about .030 diff
    what's odd is all the primary idler gears are the same, but there are 2 different gear counts on the back gear
  8. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    looks right to me on that pawl shot.
  9. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Yep, you nailed it.
  10. Brad-in-STL Husqvarna
    '80 390 WR
    Thanks! If you look close you can see the vice-grips holding a trimmed tongue depressor against the inside of the case which is acting as a backing plate for the JB weld. Just removed it tonight and it looks pretty good. Just need to touch it up with a dremel tool to ensure I've got good clearance.
    justintendo likes this.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I wondered what that was:confused:
  12. jimspac Husqvarna
    Connecticut
    I use doubled aluminum foil as a dam when I do casting with JB. Also apply a thin layer film of Vaseline to the JB surface of the foil so it can be removed after setting and not bond foil to the JB Weld
    Eurofreak likes this.
  13. 2premo Husqvarna
    Northern NV
    an easier way is wax paper
    Brad-in-STL likes this.
  14. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    I've got a spare side cover, just have to look if it's pre 85 or later, either will work by the way, if your repair
    goes south.
  15. Brad-in-STL Husqvarna
    '80 390 WR
    Good idea on the foil and wax paper. I thought about a release agent like Vaseline, but was concerned that I would get some of it on the cover and ruin my patch effort. That's why I went with wood that could easily be scrapped away.
    2premo likes this.
  16. 2premo Husqvarna
    Northern NV
    i have been using wax paper on everything i glue and clamp for like 30 years, clean-up is a snap
    RUF likes this.
  17. Brad-in-STL Husqvarna
    '80 390 WR
    And if you look even closer you'll see that I took jo360's advise because I liked the idea... thanks jo!
  18. Brad-in-STL Husqvarna
    '80 390 WR
    Now I gotta go buy some! Thanks premo.
    2premo likes this.
  19. ajcmbrown Husqvarna
    Just be careful not to grind too much off.....
  20. Brad-in-STL Husqvarna
    '80 390 WR
    So the one you have won't work, right premo?
