Oval Case Motors
Discussion in 'Vintage/Left Kickers' started by DeathFromAbove, Feb 11, 2019.
  1. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Where did you get the rims?:thinking: And can you post some close ups like the rock plate and the exhaust mounting and where did you get the muffler!:love:
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    So I am working on the second bikes motor and have some questions. Can the counter weights be welded or are they case hardened? And can i use a right stub from a later 450 in place of the right stub from this motor? Here's some pics. The original is shorter by just a little bit, will the longer 450 stub work in it's place, or do I need to get an Original :eek:
  3. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Anyone know if the counterweights can be welded and if the little longer stub will be a problem? Chris
  4. Steve-F Husqvarna
    Vista,Ca.
    1975 Husqvarna 360 CR GP
    1965 Norton G15CS 750
    DFA, give John a call at http://vintagehusky.com/ he is Da Man on Husky's :thumbsup:
    DeathFromAbove likes this.
  5. Vinskord Husqvarna
    400 CR
    Husky Club Newsletters #35 and #36 have an in-depth discussion regarding ignition stubs. This includes pictures, part numbers, flywheel size, etc. That may at least point you in the right direction. If you need the pages posted, let me know.
    DeathFromAbove and markt2 like this.
  6. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Thanks guys I'll check those news letters, and i can't imagine no one has welded a counterweight with as many rotten cranks as are found here. Thanks I'll call John in the noon hr.
    Steve-F likes this.
  7. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Well I welded the counter weight and spent 2 hrs cleaning it up, flap wheel, med file, 220 grit, 400, 600 and Crokus to finish.:thumbsup: Turned out pretty good and is really hard. All new rod with the fixin's and piston with the fixin's.:applause: I tuned the crank and got it as close as i could, looks like the drive stub is out of round about .0015, so it's still really good by MY standards.:p Got more paint for the engine, seems when i find one i like, they discontinue it!:thinking: May start the assembly soon. Been riding the 1st 360 around the tracks, it's been starting on the first kick and shifting well if you do the long pull and stomp.:cheers: Blew the headlight from who knows when, and still haven't added the tail light or battery mount and battery. :eek: Gonna be fun to ride them with my brother, I'm sure I'll kick his butt!!:lol:
    markt2 and Steve-F like this.
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Checked the Husky reports and found no reason not to use the good stub, we'll see if i have an issue with the ignition placement. More pics.
    Steve-F likes this.
  9. Steve-F Husqvarna
    Vista,Ca.
    Looking Good!!!:applause::cheers:
  10. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got it together but not bolted together yet, I'm going to replace the bolts, the socket heads are pretty worn out.
    Steve-F likes this.
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Good job! Good progress!
  12. danlboon76 Husqvarna
    Seattle
    1971 Enduro 360C
    I got the rims from Matt down at Speed and Sport. I sent my originals down with hubs. The back was a match but there’s really no replacement for that chrome valanced Raedelli up front so I just had him match the rear. Everything came back perfect. New brakes, bearings, seals, and they polished that front hub assembly to perfection. I have since found a valanced raedelli wheel, unused still in original packaging. Hours and hours of eBay. Btw that’s where the long silencer came from.
  13. danlboon76 Husqvarna
    Seattle
    1971 Enduro 360C
    D76645F9-6135-48F0-BFB3-2F5C3275F51C.jpeg 2D3FD45F-2FD1-41E7-A106-4A37066176E7.jpeg
    Cleaned it up best I could and had it powder coated. Added the rubber to avoid vibration noise.
  14. danlboon76 Husqvarna
    Seattle
    1971 Enduro 360C
    63207D3A-4818-43DA-8844-A3021B826E46.jpeg 38F5B273-8348-480A-A9B1-A05198EA6E25.jpeg A1451751-1E25-4C68-85AB-A24335B15AE7.jpeg
    I just made the clamp, haven’t put it on yet.
    Steve-F and DeathFromAbove like this.
  15. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got some sanding done today, the left cover turned out good and there is some porosity on the right cover where Garret welded a crack next to the piece that was missing that he rebuilt. Blasted them and they virtually disappeared! I won't tell if you won't!! More pics
    Steve-F and markt2 like this.
  16. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Even more!
    markt2 likes this.
  17. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    2 More!:p
    Steve-F, markt2 and dartyppyt like this.
  18. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    After the rebuild, i have not been able to get the lights to work. Today I chased all the wires to the electrical drawing and it all pans out. But still no Lights, I had them before i took the bike apart. Is there something you guys have seen that would be the same? What is the voltage from the ignition/magnito? I get 12vac from the yellow and green wires from the ignition coils on rev, shouldn't that be DC? I checked with the battery switch in battery and direct, all is correct, what am i missing??
  19. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got it, Freakin ground!:lol:
    dartyppyt, markt2 and Steve-F like this.
  20. Rosco400 Husqvarna
    I have an SI frame for sale. If you still need one, PM me.
    Rosco
    July 2020
