wallybean;132697 said:Coffee,
What is the primary drive ratio for the 4t's in question? I can give you exact speeds at rpms with that number.
wallybean;132728 said:Here are your speed comparisons between the stock 6th gear and the Motosportz 6th for the TE's.
TE 250, 13x50 sprockets, 110/100 tire, @ 8000 rpm
Stock- 56 mph
Motosportz 6th- 63 mph
TE 450/510, 14x50 sprockets, 120/100 tire, @ 8000 rpm
Stock- 83 mph
Motosportz 6th- 93 mph
That makes a huge difference in real world rideability connecting trails and cruising on the road.
 We still like you guys though!
spleno1;132809 said:Also are you speaking of just adding another gear somewhere in the case? If not would it be hydraulic or electronic? Restoring British sports cars for coming up on 22 years I can assure you their is not much good about an electronic controlled hydraulic (450 psi) over-drive. Id rather throw on a larger front sprocket, makes a world of differenceWe still like you guys though!
ducnet;134163 said:Couldn't you bump the current 6th gear into the 5th gear slot?
Coffee;134183 said:I strongly believe what you are proposing is the perfect replacement gear. Going up more would be too gappy, going up less and it would really not be worth it.
The question is, how many will buy it?
Personally, for me, it would be ideal - the only thing that would hold me back would be the installation... cause I'm not entirely clear on how to do it or how involved it is.
wallybean;134259 said:With these type of changes you are always changing a gear set. That is why the price is higher because you are paying for two gears and not just a single gear. It is the same for just changing 5th gear in the WR. A single gear is running in the $140 neighborhood and this is a mass produced item. The Motosportz price is very good with the small numbers they will be dealing with.
I can also understand the reluctance to tear into a good running motor. I always find the hardest part is removing the first bolt. Of course I really enjoy working on my bikes and it isn't all that hard for me.
Stock- 83 mph
