125-200cc Part 2: Installation of the WB165 Kit
Discussion in '2 Stroke' started by MattR, Apr 2, 2012.
  1. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Next, you will attach the upper engine mount. There are 3 bolts and the mounting brackets go in a particular orientation.
  2. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Now, attach the back PV cover to the cylinder. It slides over the oring that you installed earlier. It attaches with 1 bolt as shown.
    Next, the upper PV linkage is attached. Here is the orientation of the parts. When tightening the bolt, it helps to use a wrench/pliers to hold the outer spring tab (to prevent rotation).
  3. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Next, attach the plastic link arm to the upper post. Then, attach the lower link to the shaft. It also helps to use a wrench/pliers to hold the link when tightening the bolt.
    TIP: DON’T FORGET TO INSTALL THE COVER GASKET BEFORE ATTACHING THE LOWER LINK.
    I made this mistake and had to disassembly to put the gasket back on… oops!
  4. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Here is a picture of the PV linkage after mounting. The upper link should be in a downward position (closed). An arrow is shown in the picture how the link moves during PV opening.
    Now, install the PV cover with the 3 bolts shown.
  5. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Next, attach the lower radiator hose and spark plug.
    IMPORTANT:
    Don't forget to add coolant when you are finished installing all the parts. It is easy to make this mistake when letting anticipation get the better of you.
  6. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Finally, bolt on your exhaust pipe and silencer. And all of the other goodies like gas tank, side panels, and seat.
    I temporarily installed my CR125 FMF Fatty pipe and left the PV cover off (from previous step above). I wanted to make sure the PV was operating correctly after starting my bike.
  7. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Initial Break-In:
    I am using Walt’s suggestions for initial break-in:
    1) Start it and let it idle for ~10 minutes. Vary the rpms slightly throughout. Let it cool completely.
    2) Repeat with slightly more variance of the throttle for ~10 minutes. Let it cool completely.
    Matt’s comment: During this heat cycle, I checked to see if my PV was starting to open properly. I didn’t get stupid with WFO throttle… just enough rpm to see the linkage move to begin opening the PV.
    3) Now go for a gentle ride keeping the engine rpms below the power valve opening ~10-15 minutes. Let it cool and then take a compression test. Note: engine should be warm with taking the compression test. This will be your base line for top end health.
    4) Now go ride but try to keep away from extended WOT runs for the first 30-60 minutes. It would good to do a throttle chop plug check at some point early in this ride to verify your jetting.
  8. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Here is my compression test (done after Step #3):
    I ran my bike briefly until engine was warm.
    Installed my Craftsmen compression tester with 14mm long attachment.
    Using WFO throttle with 10 strong kicks.
    1st trial = 195 psi
    2nd trial = 180 psi
    3rd trial = 185 psi
    NOTE: Later, I will test it again after my first “real” ride (step #4 from above).
    Here is a comparison between 14mm long and 14mm short attachments. The 14mm long has equal length to spark plug and was used for my tests.
    Here are pictures of my compression test results:
  9. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Other Goodies:
    After my break-in heat cycles, I mounted up my KTM 200SX FMF Fatty pipe that Walt built for me. My bike is a 2008 CR125 frame, so Walt had to cut & weld brackets for my mounting location.
  10. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Also, I’m using a KTM junction coupling for a better seal. The Husky coupling leaks too much.
  11. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    She’s ready to ride…
    john01 and Petar like this.
  12. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    An very special thanks goes out to Walt (Wallybean). I appreciate all of the effort that you put into the WB165 Kit. My bike has been transformed into a fantastic woods weapon!
    john01 likes this.
  13. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Here is my compression test (done after Step #4):
    I did my first real ride (approx. 2 hrs) and used the full throttle range. After I got back home, I ran another compression test to compare with my prior results.
    I used the same procedure as last time...
    1st trial = 195 psi
    2nd trial = 195 psi
    3rd trial = 188 psi
  14. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    {reserved for future post}
  15. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Well, this concludes the installation process that I used. I think it would be great if some of our 2-stroke gurus could share their tips/tricks below. I'm sure there are areas where things are done differently. Let's make this thread a collection of "how-to" instructions for installation of the top end.
    huskybear, wallybean and john01 like this.
  16. lankydoug Husqvarna
    MO
    WR
    TM 300en
    That is pretty cool. The only worry I'd have from looking at the pics is how low the pipe hangs down, I'd have it smashed in about a week.
  17. john01 Husqvarna
    Powhatan VA
    Awesome post. Thanks for taking the tme to do so. Oh, Lankydoug is right that pipe is to low and must be removed...please ship to John ASAP :D.
    MattR likes this.
  18. wallybean Mini-Sponsor
    Montana
    Doug,
    I thought the same thing when I first mounted mine/Kelly's. Rode in some seriously rocky gardens and narrow mountain crap holes. Never made a real dent in it. :excuseme: The pipe guard does help this pipe alot but I think it isn't in the way as much as it looks. Lots of rocks, downfall trees and various crap with no dents yet. Maybe it is the extra strong mounting and welding. :lol:
    Matt,
    You should have been a surgeon. Fantastic posting and should be a mandatory read before doing a re-build for anyone that is worried about the process. Thank you for all your effort and time. :applause:
    MattR likes this.
  19. wallybean Mini-Sponsor
    Montana
    Doug,
    I went out and compared my 360 pipe location to the fmf 200 fatty on the 125 and the 360 pipe is far more exposed on the bottom. Mostly because the pipe is tucked in tighter to the motor and farther from the front wheel. The fatty on the 125 where it is lowest is also pretty close to the front tire so most of the trail crap is beyond the pipe and nails the skid plate/frame rather than the pipe. Sounds good in theory. :D
  20. john01 Husqvarna
    Powhatan VA
    Any word from FMF? What year SX200 pipe do we need?
