125-200cc Part 2: Installation of the WB165 Kit
Discussion in '2 Stroke' started by MattR, Apr 2, 2012.
  1. john01 Husqvarna
    Powhatan VA
    Any word from FMF? What year KTM 200 pipe do we need?
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Looks good Matt! Bike looks Sweet!
  3. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    I believe Walt used a 2003-2004 200SX. Hopefully, Walt will chime in.
  4. john01 Husqvarna
    Powhatan VA
    Thanks Matt that sound right.
  5. Chris Sykes Husqvarna
    wr 125
    Cracking guide! Your teardown already helped me and this will be getting printed off and used as soon as my piston kit arrives!
    Couple of quick noob questions...
    Where are the journals that you dropped a couple of drips of oil down? are these the two holes on top of the bottom end? Is 2 stroke ok for this?
    How do you lube the big end bearing? just drip a little oil to the side of the conrod?
    What and where is the locating pin? I see your new piston ring gap is towards the inlet side, is this the way it needs to go in?
    Thanks!
  6. Motosportz CH Sponsor
    AWESOME post. Thanks so much for doing that. :thumbsup:
    MattR likes this.
  7. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Yes , you will use your premix oil for the lube. Like you described, I dripped in the spaces along the sides on the conrod. I was more generous than probably needed, but it can't hurt.
    The arrow on top of piston points forward to exhaust. This will make the locating pin in the ring slot be on the inlet side. After you put the ring on, you will need to squeeze the ring and keep it centered on the pin as you install the cylinder.
    Chris Sykes likes this.
  8. Kevin_TE250 Husqvarna
    Boise Idaho
  9. Kevin_TE250 Husqvarna
    Boise Idaho
    Never mind... Went back and read the post.. Custom design.. Nice work !
  10. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    THANK YOU THANK YOU THANK YOU for the write up!!! I had never been into an engine that far before. It was super simple, I mean really simple with this guide!! Great info on both tear-down, and build... Even though i read about the power valve gasket, I too, put the linkage all back together, then realized I forgot it!!!:banghead:
  11. meusoc45 Husqvarna
    Portland, OR
    2012 WB165
    Hi Matt,
    What KTM junction seal did you use, was it for a 200SX model? My Husky seal leaks badly. Thanks, R.
  12. wallybean Mini-Sponsor
    Montana
    Use the one for the 125/150. It is a tight fit but it never leaks.
  13. meusoc45 Husqvarna
    Portland, OR
    2012 WB165
    Thanks Walt for getting me squared away. My bike flat rips. Richard.
    wallybean likes this.
  14. TROFFER88 Husqvarna
    Camas Wa
    Here is my 165[IMG]
    [IMG][IMG]
    Ooooops and my new GG
  15. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    Is the GG a 300? very nice! how do you like it?
  16. TROFFER88 Husqvarna
    Camas Wa
    250 best bike I have owned period
  17. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    Sexy bikes Tim I dig your style (In a non-gay type of way) :thumbsup:
  18. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    Does it feel smaller than the 125 when sitting on it? looks slightly more narrow? how does it compare in weight? really looks nice
  19. hammer Husqvarna
    My wife rides the same bike and I agree with you. Amazing motor and handling of a 125.
  20. wallybean Mini-Sponsor
    Montana
    Damn Tim, I swear every bike you own is the the Shitznizzle!
