Piston / Rings Replacment Discussion
Discussion in '4 Stroke' started by Fast1, Feb 20, 2009.
  1. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I don't plan to go that far into the motor. I'm just going to pull the head and cylinder, but if I needed a rod or crank work, Falicon would be first place I'd call.
    Eurofreak, are you sure about pulling the top end while the motor's in the frame? It looks awful close.
  2. Huskybloke Husqvarna
    maitland AUST
    yep i understand how that would do that.cheers
  3. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    To answer my own question, yes, you can pull the top end while it's in the frame, barely. I had to disconnect the front cam chain slider to get it off on my TE.
  4. tref Husqvarna
    montenegro
    I was tray to pull off cilinder head when motor is in the frame and not possible,this is on sm 510r 2007 year,:banghead:
  5. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    '08 te510. Not sure about any others.
  6. dirt rider x Husqvarna
    Australia
    04 TE450 definately wont
    :thumbsdown:only misses by about 6mm
