All 2st Please post pictures of your 2 stroke bikes.
Discussion in '2 Stroke' started by Coffee, Dec 28, 2008.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Haha gold mate! Must've bn pretty flowing terrain to get that sort of economy? Yep always a few minutes of adjustment wen I go from 300 to 165. I love gettin up Hillsboro over stuff the bigger bikes can't-really shuts people up n u don't need to say a word they know!:)
  2. Ran Caulfield Husqvarna
    Qld Australia
    12 Wr300,13 WR125
    none at the mo
    Yeah mate,I think thets part of the attraction the challenge of doing stuff everyone thinks you need a 300,450,500 for.
  3. Ran Caulfield Husqvarna
    Qld Australia
    12 Wr300,13 WR125
    none at the mo
    Hey mate was just looking at vinduro's suspension numbers etc do you know what rear spring you're running on ya 125?
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    You can calculate proper springs rates at the RaceTech site:
    http://www.racetech.com/ProductSearch/1/Husqvarna/WR125/2012
    I weigh about 75 kilos ready to ride and run .40 fork springs and 5.0 shock springs on both bikes.
    300 is plush, but not too soft and 165 seems a little stiff, but works good. Sags on both are spot on.
    :cheers:
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I like it when she gets dirty ;)
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    5.8 rear .48 front but I'm 100kg(give or take a few kegs-normally give!) so 110kg+ with gear. Dave at suspension matters recommended .48 n 5.6 but I already had a 5.8. Havnt checked sag in ages cos I'm lazy n misus is useless at helpin do it.
    Oldscool likes this.
  7. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    RC, I'm 80kg starkus and went with a 5.6kg/mm (5.0 is standard). Quite an improvement of the rears performance, most noticeably, plusher over the small stuff with more travel control on bigger hits.
    To put this in perspective: I'm a 49 yrs old, 5'8", average fitness trail rider who rides at a 'relaxed' intermediate pace.
  8. Ran Caulfield Husqvarna
    Qld Australia
    12 Wr300,13 WR125
    none at the mo
    Yeah my misus is a bit the same ,they just don't get it!! I have the 5.4 out of my 300 so gunna throw that in and see what diff. that makes,I'm about 83kg without gear so probably 95kg+ all geared up might get me close to the numbers.
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    I reckon I should b at a 6 really but for trailridin one rate under should be fine so reckon ul b spot on. Iv had mine on few mx tracks n at my slow pace with no adjustments it was sweet. Only bottomed on big flat landings. If u were hittin bigger jumps(& or Ridin faster like A grade pace) prob wanna firm it up with the clickers at least but they ain't mx bikes really!
  10. freejack Husqvarna
    New Zealand
    2008 WB165, 95 WR125
    92 wr200, 88tzr250, & Beta evo300, B
  11. freejack Husqvarna
    New Zealand
    This is my 2009 CR/WR/WB 165 , started life as a cr125 which was converted to WR speck as the New Zealand Husky importer couldn't get me a WR,
    Last December I fully rebuilt it, powdered-coated the frame, replaced every bearing bush & seal, sent the barrel to Wallybean for the 165 treatment, also got a -FMF gnarly & FMF Q stealth muffler, Rekluse 3.0 clutch.
    Usually I have a Vee rubber Trials tyre on it but swap to a knobbly for the winter months where I tend to ride at the local cross country which has lots of deep sand and big ruts - very good for conditioning & fitness.
    Dirtdame and NCSteve like this.
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Gnarly or fatty? Didn't know they made a qstealth for these or did U fab it to fit? Is it fair bit quieter than stock solencer? Looks like an 08 or older model by the frame/swingarm/discs.
    Looks good with the blue mate.
  13. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    FMF pipes and mufflers fit FMF or stock pipes and mufflers. I had a Qstealth with stock pipe on the 300, tried a Gnarly and didn't like it with my setup. Broke the Q's mount in a fall and been running re-packed stock for awhile. Q is quieter at hi R's, bigger too.
    :cheers:
  14. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    The FMF Q I bought for my 300 didn't fit. Everything lined up, but the diameter of the slip-on pipe was about a half a millimeter too small. I took a grinding stone and hogged it out till it fit.
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeah but it's a 125 not a 300.
  16. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    Had a similar problem with the Fatty on my CR150. Pipe was too big by about .5 mm. Had to open up the stock silencer to fit.
  17. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Well, they're supposed to fit :rolleyes:
  18. freejack Husqvarna
    New Zealand
    Hi the pipe is a Gnarly i think , it was sorted out and modified to fit by Wallybean when he did the engine mods , was originally for a KTM 200, the qstealth was one to fit a GAS GAS300 which i got for $150.00 from a GasGas dealer who quit there stock after they stopped supplying New Zealand, it fitted up without to much modification by a local exhaust shop, noise wise its not to bad between my trials bike & and mx bike so I can live with it. You might be right with the year, even though it was new in 09 i did get it very cheap so they could of been clearing out old stock.
    shawbagga likes this.
  19. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Walt usually supplies Fatty pipes with the 165 kits, the 200sx version proved to work best.
    :cheers:
  20. freejack Husqvarna
    New Zealand
    I checked the paperwork and yes its a fatty
