Poor handling 09 txc 450
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by andyman, Mar 28, 2010.
  1. andy j Husqvarna
    colchester uk
    andy man.. my 2 lines was the fork height through the tripple clamps on the outside..
    people better than me have suggested that if the fork height is adjusted to the first line this will promote a more stable front-end at speed. You can raise or lower the fork from this point as a means to quicken or slow the steering respectively ie more rings showing better turning more rings more stable at speed..
    thanks
  2. andyman Husqvarna
    DOH! Yep. I mis-read what you were telling me. Yes, I definitely need to play with the fork height. Mine is currently 2 lines down as well.
  3. ghte Husqvarna
    Bright, Victoria Australia
    Please take it to a suspension guru and have it set to your weight and primary type of riding. I can tell you that the Husky is light years ahead of a 03 kato in all facits of steering, breaking, suspension and cockpit geometry. I ride with those bikes all the time and we swap rides quite often. In fact I find the new KTMs to be pretty loosy goosy to ride-hard to pin point the cause they just feel slightly viby and vague. The Huskys have a really planted and solid feel about them.
  4. Coffee CH Owner
    If it is that obvious that is good news actually, it will be easier to figure out.
    Great idea!
    • Change everything you can think of.
    • tire pressure up/down - on both ends (way up and way down)
    • fork height up/down
    • change the sag, or what would be easier is to add 2 gallon jug of water somewhere on the bike for added weight
    My point is, you can do some massive/weird things, for a short test ride, and get decent information. Then send the suspension off to a tuner, if that is your direction. The information you collect should be useful regardless.
    I drove myself nuts trying to figure out why my bike rode terrible on the street at 25mph, but others thought is was ok. Those other people weighed much more than I did. Finally I strapped 4 jugs of water on (for testing) and really noticed the difference. My problems were a combination of wheel balancing, and in the end, a re-valve of both ends.
  5. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    Loose spokes may not be your issue, but you need to have had a wrench on them at least a couple off times since new. I know this as I have a set of spokes sitting right next to me for my DRZ, that I neglected to tighten during break in. Needless to say it felt terrible untill the spokes were tightened and then 2 broke later on while truing the wheel.
  6. ray_ray Mini-Sponsor
    The Philippines
    I had the same issue with my 02 model CR ... Guys that weighted >40 lbs more than me would ride my bike and liked the suspension ... and it would beat me to death when riding ... I had to have it re-valved for the trails ...
    This TXC has been alot friendlier bike for this ~150 lb guy :) At a rider weight of ~230 ... UR fork springs might need changing to something stiffer ...
  7. Gasserman Husqvarna
    Montana
    01 cr 165
    ktm gasgas
    Just curious what from tire your running on your bike? my 09 450 with the stock michelin felt really loose, pushed through the corners, and was just scary to ride, i changed the front to a tire i liked on my 09 ktm
    and that made alot of difference, then i changed the sage to 3.5, and set the front tubess at the second line, and now as far as chassy/handling, they are pretty equal.
    Just my 2 cents
  8. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Good tuning info here guys. I hope that helps you, Andyman.
    Just for the record, my 09 TE450 is at two lines above the triples and works great. It was at three lines when I received it and it was twitchy. Dropping one line calmed things down just enough.
  9. andyman Husqvarna
    Yeah, good stuff. Thanks for bringing up tires! I hadn't thought about that. I do have the stock michelin, and suffer some of the same charicteristics that you described.
