Pottering around...
Discussion in 'TR650' started by glitch_oz, Jan 20, 2014.
  1. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Most of my sound increase is because there is no filter in the front echo chamber. The stock filter position would muffle the sound some. With the airbox still intact, it acts like a resonating chamber. I'm most likely going to get a real coarse pre filter and just put it in the front. I have seens some scotch bright material, thicker like for cleaning a grill, that might work nice.
  2. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    RE: The short brake line. Contact HEL in brisbane and give them the fittings and the angle and the banjo bolt threads ( you get new Stainless banjo bolts and proper copper gaskets with the line) and they will make you a custom brake line in whatever colour you want in what ever length you want. Don't it many times for my race bikes ( ususlly shorter for rearsets and clipons). In most bikes it will improve the braking as well but the std Husky brake lines are very high quality low expansion so that extra benefit won't be there. NOT EXPENSIVE and usually cheaper than oem ones. You can even get titanium banjo fittins and bolts ( I wouldn't even on a racing bike). And very prompt service. VERY HIGH QUALITY Aussie made product. I have bought heaps of pairs over the years and even have them on my BMWF800R ABS system ( wider bars, master cyl to ABS)
    http://www.helperformance.com.au/
  3. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    Just looked at the new site. They have a custom line build section now but if you are unsure ( banjo bolt threads can be a pain) ring them)
  4. glitch_oz Husqvarna
    AUS
    Strada
    I'll see if the stock sprocket cover is modifyable for function without turning out looking too shabby.
    Re: foam strip. It keeps most of the extra filth out of the airbox (the hacksaw cut finished up ~1-1.5mm/ 1/16 wide once cleaned up) and baffles about 30% of the extra noise as it stops the different frequencies caused by the 2 differently shaped+sized airbox-lid halves.
    Mag00 is right, though...the thing acts as an echo chamber and some "baffle" material would be good.
    Will try the stocking-ed OEM-filter frame first though.
    Was thinking of some very coarse stainless steel wool (coarse pot-scrubbers used mainly in commercial kitchens.....and Staintune exhausts ;) ) as that can also be quickly washed in petrol/ soapy water/ kero....whatever is around at the time.
  5. glitch_oz Husqvarna
    AUS
    Strada
    Thanks!
    Been talking with John from John Stamnas/ Goodridge in Cooroy about it at length (as they also make custom braided lines etc and we've known eachother for a long time)
    The problem with the line is that it's a machine-joined single line made from 2 different tubings, the rigid line from steering head back to ABS unit and the front part braided line from steering head to master cyl.
    The joint is NOT a screw fitting, but pressed. Essentially it's a one-piece line from m/c to ABS pump. The flexible part can not be detached and/ or replaced. The rigid line follows certain hookup points and guides around various other components and can not easily be replaced by a flexible line without modifying all the fixation points/ changing routing etc etc.
    Anyway, it's all fixed now and I got the "extra" length required out of a slight straightening of the rigid line around the engine.
    Looks like someone just wanted to make some extra curvy bends that day on the assembly line and ate up about 40mm/ 1.5" in length that way.
    Nothing new...been mucking around with Italian bikes for years and just about NOTHING is impossible :D
  6. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    I like the BMW X-Country sprocket cover as well, but also looking at the two available case guards, the Scheffelmeir and the Rafel.
    Cover or case saver, what's your preference, aside from the cost of either?
  7. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
    +1 on the write up, glitch. Took me a while to place your name, but than I remembered your posts on the "Thinstrom" : http://www.advrider.com/forums/showthread.php?t=251613 Awesome stuff !!! :notworthy:
    trzcharlie : Looked for some sprocket covers too, Touratech and Scheffelmeier respectively, but was not willing to pay the $$$$$. Had some 3/8" aluminium plate and 1/4" spacers in the shop. Came up with that:
  8. glitch_oz Husqvarna
    AUS
    Strada
    Oh boy...that "ThinStrom"-stuff is starting to become a trade mark :D
    That was the first 650, The Shrek.
    It's sold and living on as a Super-Motard in the cleaner road-environment, raising hell where ever it appears, hehe Great bike :-)
    Here it is between the 2 earlier VStrom 1000's
    Whow, that's one hell of a sprocket cover!!:applause:
    For some decently priced Xcountry covers log into Ebay.de and pop this into the search box:
    Ritzelabdeckung BMW G650
    There are currently 2 listed, used, @20Euros each plus postage (which won't be much on a small article like that.
    When buying, tell the seller to remove the German sales tax (MWST 19%) from the listed price as the article
    is sold to a place outside the EU.
    In the meantime, here's one version of what can be done with the stock-cover.
    Pics to folllow, upping now
  9. glitch_oz Husqvarna
    AUS
    Strada
    After the first chop, grinding away about the left 1/3 of the cover, keeping the fixing lugs and cutting through part of the top edge for access to the oil-filter screw.
    Screw is clear, that part's out of the way.
    Following the Xcountry theme...
    Looking fine after "freeing up" the top locating lug
    Time for a good clean-up, de-burr, re-sealing those ground edges and cuts with an open flame and soldering iron to get the black colour and finish/ texture back, remove the paw-prints and try to cover that shallow scratch where the drill slipped with a rag soaked with some still-wet satin-black out of the rattle can.
    Not bad for what started as a " I'll give it a quick whirl and see how it turns out" and finished up the usual "2hrs, 1 bandaid on the bloodblister and a burned lip from the hot tea affair" :banghead::lol:
    PaulC and mag00 like this.
  10. drzcharlie Husqvarna
    That looks really good! Nice job...but damn, now I gotta try it.
  11. Clete Husqvarna
    Tigard, OR
    Ya, very nicely done
  12. drzcharlie Husqvarna
    Ok, it was a fairly easy mod thanks to Glitch! Draw the lines to your liking, buzz em with a jig saw, drill six holes for the slots, connect the holes with the jig saw, and now I have to debur. Works fine, gives access to the CS bolt and the oil filter housing and it's free. Thanks
    I also decided to take a piece of 2 1/2" aluminum conduit I had around and make a rear brake reservoir cover.
    All in all not a bad day. I saved about $140 USD by doing this DIY
    Moff69 likes this.
  13. macntatsch Husqvarna
    SoCal
    '14 500 EXC, '07 FJR1300
    This looks like a good 3D printer project. Maybe we can talk one of the ADV guys who volunteered on the airbox mods to draw this part.
  14. drzcharlie Husqvarna
    This is very easy to do. Took me all of 45 minutes to complete. But the 3d idea is a superb one.
  15. glitch_oz Husqvarna
    AUS
    Strada
    Nice going.
    Like the shape. :-)
    And yes, it's easy enough to do... and costs nada.
  16. Thumpa Husqvarna
    san francisco bay area, california usa
    TR 650 Terra
    CCM Dakar, G650X
    Hansi - what ya' got goin' on there mate, is that an auxiliary tank line i see? Do show and tell if you get a chnce, looks interesting!
  17. glitch_oz Husqvarna
    AUS
    Strada
    Made from an old V-Strom handlebar-weight bolt and various rubbers, spacers, washers etc to principally make a rubber-"dowel"/ plug for the steering stem-tube that will be a pivot for a tankbag front-mount-loop at the same time.
    Sounds complicated....but easy...just a bit fiddly.
    The tankbag is an old Aprilia-Pegaso OEM jobbie, garage-orphaned for years...great quality bag, but not the right shape for the current D/S bikes.
    Frame plugs made from some EVA-offcuts I had floating around at work.
    Siliconed into place, removable if need be. Weight 1/4 ounce (pair), solid, waterproof.
    Heavy alum fly-mesh from the hardware store and a bit of Polyprop sheeting (leftover stiffeners cut out of some old soft-luggage bags) make for some radiator protection (bug screen + " first defence") , together with some mud/ spray guard for the lower portion.
    Easily removable/ cleanable/ lightweight/ cheap/ ....and black! ;)
    Top of the mesh us just cut and bend over the top of the radiator, using the 2- hanger-screws to hold it in place.
    Bottom is semi-wrapped around the crash-bar crossbars and cable-tied.
    Moff69 likes this.
  18. drzcharlie Husqvarna
    Glitch, Your mod Looks good!
    I tried the screen material you have. My bike got too hot after clogging with mud. I ended up changing it out for expanded metal. Works fine without overheating. I painted it black
    with a rattle can of truck bedliner material. Tough as nails.
    with [IMG]
    PaulC, glitch_oz and Scutler like this.
  19. glitch_oz Husqvarna
    AUS
    Strada
    Fair enough...I'll see how I go. Planning to do something about that front guard, too....hopefully preventing that sort of thing.
    Finally got the last few bits for the Pod-Mod, finishing off that chapter, hopefully.
    Xmas came early....a small mountain of 2. hand/ but as new stuff bought here, there and everywhere over the last 3 weeks.
    More garage fun on the coming weekend :-)
    PaulC likes this.
  20. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
    Went to a single left side exhaust and had the right one to play with and after gutting it and adding a 3" piece of stainless pipe I ended up with a 1.25 gal aux. tank.
    It is a work in progress, still looks rough and I have yet to find the right color paint to match the can on the left.
    glitch_oz, Moff69, PaulC and 2 others like this.
  21. Thumpa Husqvarna
    TR 650 Terra
    CCM Dakar, G650X
