We (Motosportz) have been asked a lot about rotors. So we did something about it. We now have them, front (with the magnet hole) and rear, in stock. I'll post pix soon. about $90. Email me if you need one at motosportz@gmail.com Thanks! Kelly
the front should fit everything from about 2000 and newer, basically any 4 bolt off road rotor as far as I know. The rear should fit any 240 mm rotor bike like the 08 TE/TC/TXC. I'll find out more shortly. K
What brand are they and are they a rigid mount or floating like the stock Te-610 (dirt model)? Thanks
Here is the info / pix. They are "Braking" brand. Front: Solid mounted like stock Standard dia front for all bike but SM's (about 260mm) 3.15mm thick Rear: Floating mounted 195mm dia 4.07 mm thick $89.95 per, will have them on the web site tomorrow. Thanks.
I need a front rotor for my 04te510, can you hook me up? I also need a few more things not listed on your website, can i order more parts from you guys or just whats on the website? I need a mudflap , forward chain roller , and a rear brake lever (just the tip if it's available)
We just has a discussion on other brake lever tips that could work if you are interested: http://www.cafehusky.com/forums/showthread.php?p=29550#post29550
very cool- those look identical to my 09'te's - my brakes are awesome at the moment- very strong. Its hard to get used to other peoples weak brakes after the husky's- whether theirs are poorly maintained or just not as good from the start- my brothers exc 450 always seems to have weak brakes- my exc is better but the rear is always soft- not as definite as the husky's.
Hey Kelly, I want to pick up a front and a rear, I emailed you last friday and have not heard back. Are these available yet?
