XLEnduroMan
Heroes Ride Huskys. The others follow.
Is that a SM front fender on that beauty?
Just added a added a Ballistic Evo 2 BATTERY WEIGHS 1.8 LBS ,BIKE IS NOW 311 LBS FULL OF GAS.
good eye yes it is.Is that a SM front fender on that beauty?
That is very impressive! 311lbs-20lbs (fuel) dry weight is about 291lbs. Can you tell all mod what you made for loosing about 40lbs?
I want do the same mods!
Going on its first real 50 mile offroad tomorrow,hres more pics.The tail light rubber mount just goes up under and bolts into the 2 tail light mounting holes one of the pics shows this.billf
TE511 kick stand is 2.5 in. longer PN#8000H0233 bolts right on.$63.87
We also noticed the complete Te511 front end made the front wheel center 1 in. longer from the frt motor mount.
bRING IT DOWN WE CAN DI IT.>RACED WASHOUGAL ,FIRST RACE SINCE 2006 WENT GREAT HAD A BLAST ON THE WR150
+1, I can't use it comfortably at all...What I want is something to lower the rear brake lever, maybe as far as an inch.
I swapped out my stock pegs for some 510 pegs. They're a direct fit.+1, I can't use it comfortably at all...
