125-200cc Pros and cons of a Revloc Dyna Ring for a WR144 woods riding?
Discussion in '2 Stroke' started by homespun1, Apr 6, 2015.
  1. homespun1 Husqvarna
    Gotcha and thanks. As of now, my handlebar clutch adjuster is close to maxed out and the bike just slightly wants to crawl in gear. The clutch is a bit harder to pull. My only concern is that even when the clutch is engaged, and I hit the throttle you can feel the bike want to move just a little when still and when riding.
  2. Norman Foley Husqvarna
    Wise words! If you like the auto clutch, an EFM is hands down the best unit for the WR-CR125/144/165/177!
  3. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    2011 GASGAS EC 300 2007 KTM 200 XC
    Maybe try another shim, That should give you more cable adjustment and put the cable pull in a better place.
  4. homespun1 Husqvarna
    I already have the larger shim and two thinner washers installed. I am wondering how many I can place as it sitting flush now in the center ring.
