PVL troubles
Discussion in 'Vintage/Left Kickers' started by oldnslo, Jun 19, 2016.
  1. oldnslo Husqvarna
    Pa.
    1974 husky Mag
    Ktm, Honda, Suzuki, Kawasaki, Yamaha
    Flywheel has been painstakingly lapped to perfection ! .torqued but not keyed. Going to key it this weekend if possible. Not quite sure what the issue is in earnest with my bike but some small anomaly is causing this flywheel to spin ever so slightly on the shaft....ripping it it today for the final time...
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    my 400 is a Californian scoot so a motosplat is std
  3. Kartwheel68 Husqvarna
    Newnan, Georgia
    I dont think there is enough thickness in the steel insert of the PVL rotor to cut a keyway. I have never heard of a correctly lapped PVL rotor slipping, there is some other issue going on here.
  4. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Guess who told me PVL s are not very good and don't ever recommend them for big bores. PVL reps at Penton imports . I sent in my PVL unit that was
    on my Maico 490 for checking. It did not start. Checked perfect. Says we did not recommend are PVLs for open bikes of for any bike that has a slow kick
    ratio. So many are also having trouble on their 250s now also.
    I would retire that unit and replace.
    All my bikes have Electrex units on them now. And about 8+ folks now here on this site have them on their Huskies now. All working fantastic and no kickbacks either
    oldnslo likes this.
  5. oldnslo Husqvarna
    Pa.
    1974 husky Mag
    Going with the electrex now myself. Tired of messin with this darn PVL ! Junk IMHO !
    Can I ask where you bought your electrex ?
  6. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Ah
  7. Kartwheel68 Husqvarna
    Newnan, Georgia
    I would never recommend a PVL for a 250 or above, I made that mistake myself once 10 years ago with my Maico 440, but I have 6 on various brands of 125/175s and they work flawlessly on the small bikes. I would recommend the MZ/B-Powerdynamo for a 250 or above.
    However, the PVL flywheel should not come loose no matter what size bike it is on, I suspect something was wrong with that particular flywheel or his crank snout.
  8. oldnslo Husqvarna
    Pa.
    1974 husky Mag
    I couldn't agree with you more. I have PVL's on a few 125's with zero issues but on anything bigger than a 175 forget it....the crank end was the issue. It's since been corrected and a MZ has been added. Perfect now on all fronts.
  9. Kartwheel68 Husqvarna
    Newnan, Georgia
    Depending on the 250, like a Maico with a relatively heavy crank, you could use a PVL but any 250 like the Japanese bikes, and especially the Penton/KTMs, have light cranks so they need an external flywheel. My Mag 250 has a PVL on it and with a '78+ kicker it starts fine and runs great, but with the stock kick lever you just cant spin it fast enough to generate good spark. After my frustration with the Maico 440 I'll never put a PVL on an open class bike.
