Kyle Tarry
		NOTE: Some of my initial calculated values for the Keihin needles were off.  They have been corrected, but some of the comments may refer to the earlier (incorrect) values.
I am trying to get my carb dialed in the last little bit on my WR, and I thought it might be a needle issue, so I took some measurements:
JD Blue, measured from the top clip:
Location (mm)Diameter (mm)
6.35 2.870
12.7 2.870
19.05 2.680
25.4 2.667
31.75 2.667
38.1 2.464
44.45 2.261
50.8 2.083
57.15 1.981
This works out to a base diameter of ~2.67-2.68, and an initial taper angle of about 1.7 degrees.
Then I looked up the specs for a CEL needle (I do not have one to measure, yet):
0 2.705
6.35 2.705
12.7 2.705
19.05 2.705
25.4 2.705
30.8 2.705
38.1 2.516
44.45 2.350
50.8 2.184
57.15 2.018
63.5 1.851
The base diameter for a CEL is 2.705mm, and the taper angle is 1.5 degrees.
It looks like the CEL should also be leaner at idle and light throttle, due to the larger base diameter. Once you get onto the taper the needles are similar, although the JD is going to get richer a bit faster because the angle is a little bit steeper.
Can someone with a CEL measure it for me (or I guess I can just buy one, I'd like to try it anyway)? I will pull my JD red tonight and measure it to add to this info...
6.35 2.870
12.7 2.870
19.05 2.680
25.4 2.667
31.75 2.667
38.1 2.464
44.45 2.261
50.8 2.083
57.15 1.981
0 2.705
6.35 2.705
12.7 2.705
19.05 2.705
25.4 2.705
30.8 2.705
38.1 2.516
44.45 2.350
50.8 2.184
57.15 2.018
63.5 1.851
