Experimenting with running my car on sea-water (yes that's correct) we found the simplest way to trick the O2 sensor into allowing oxygen rich exhaust was to lift the sensor 18mm out, the sensor would then run cooler, hence higher oxygen leaner mixture The reverse for Husky's which need to run a little richer, the sensor needs to run at a higher temperature
