race fuel
Discussion in 'Vintage/Left Kickers' started by justintendo, Oct 31, 2015.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    im using new or jets that have sharp markings. race fuel does make things richer, at least from what ive read.
  2. fran...k. Husqvarna
    eastern ct
    Oxygenated race gas would need more of it as some of the oxygen is in the fuel as opposed to the air. If you really want maximum power and oxygenated fuel is not illegal in whatever endeavor you do at least consider it. Just like Alcohol, methanol race fuel more is needed. The dirt bike magazines run dyno tests (stock vs modified) on race vs pump gas, or at least they have. It all depends on what one wants to do. Internet forums seem to be more on the set up than average recreational or utilitarian users.
  3. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    Not to change the subject but in a pinch try a gallon of toluene to 4 gallons of 93.
    I usually use VP C-12 bike is jetted for it and it's nice and crisp. Putting pump gas in it makes it feel like it has a flat tire.
  4. vintagecs Husqvarna
    Lebanon, IN
    '78 390OR, '76 360 Auto, '74 125SC
    Penton, Yamaha
    Pump gas mixed with AV gas. How long will the mixture stay good with pre-mix oil?
  5. justintendo klotz super techniplate junkie
    in the past my friend and i ran a form of vp that was oxy and indeed we had to add a bit of fuel. had good results with it.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I've been told 90 days is about all you can expect out of pump gas unless you use additives and then 6 months before it starts to go bad. I've never seen any data on a pump gas race fuel mix.
  7. MotoFo Husqvarna
    Richmond, CA
    1974/5 250CR, 1981 430CR, 1986 400WR
    Yamaha TY175, Yamaha TY250, CRF150F
    In Calif. non-ethanol gas is not readily accessible. I suppose my only option is to run AV gas with pump/ethanol gas? Or would it be better to run straight AV gas?
  8. cognitive 390 Husqvarna
    Tetraethyl lead was added to gasoline back in the day to increase octane to help eliminate pre-ignition/pre-detonation and/or ping as engine compression ratios increased for performance. They also discovered that it helped lubricate the valve train in four strokes. in the early seventies they (government) began to stop using lead in gasoline because it increased emissions and was found to be dangerous for humans. By the late seventies it was all but gone from pump gas. You could however buy it for off-road/racing purposes only. Most all of my bikes (H2 kawasaki, CR 390's, KZ 1000 and IT 125) required around 98 octane to run well especially in the heat of Arizona. Higher octane also helps with heat issues in internal combustion engines (pre-ignition). The myth is that some people believe higher octane will boost horsepower...wrong! If an engine is running at peak performance and does not ping, pre-detonate/pre-ignition, it probably doesn't require higher octane. However, if one boosts engine compression ratios, ports, performance pipe etc, it very well may need a little increase in octane. It is also possible to "over" octane an engine and it will not run at its best. Too cool for school! Here in Phoenix I have access to all sorts of racing fuel. VP and Sunoco are two biggies. If and when I buy from them I use VP MS 98 L ( 98 octane leaded). The nice thing about buying that stuff is the shelf life is triple due to no ethanol in the fuel. Today's pump gas has a short shelf life due to all of the junk additives most of which is ethanol. Another option (and cheaper) is to buy octane booster) But not just any octane booster. It needs to be Tetraethyl lead. That is the only stuff ( that i believe) does a good job at increasing octane levels. Hard to find stuff! However, Kemco Industries is again making Octane Supreme. Whether I use VP 98 or Octane Supreme all of the bikes run excellent. I stopped using Oxygenated fuels several years ago as I got tired of cleaning carbs. I also run the bikes until carbs are empty of fuel. Gas will keep better in the tank than carbs.
    lankydoug and troy deck like this.
  9. cognitive 390 Husqvarna
    PS use caution using aviation fuel. They use additives to deal with extreme elevation. Some two-stroke oils will not mix well using aviation fuel.
  10. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    It's amazing that just over the boarder in AZ it turns back into a free country. Access to cheap fuel, lots of race gas that comes out of pumps, plated 2 strokes, no nanny gun laws. I know every time I head east i make sure i have just enough gas to make it across the state line where it drops by almost $1/gal.
  11. cognitive 390 Husqvarna
    LOL. Ya, my father lives in Fallbrook Ca. He calls it the socialist state of California. I lived there many years myself. Now, if only someone could do something about the hot summers!
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    I hear Flagstaff is nice in the summer.
  13. cognitive 390 Husqvarna
    Yes, we go there in the summers to escape the heat. When I was growing up in S Cal one of my favorite riding spots was Gorman (Hungry Valley). Have you ever ridden there? Also rode Indian Dunes and Saddleback but really enjoyed Gorman.
  14. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Grew up there! Gorman was the place. Indian Dunes was getting plagued by insurance issues so never rode there before it closed for good. Hungry Valley is probably one of the best family friendly areas there is. Here is s pic of my son from a ride there last year. 20150418_143414.jpg
  15. cognitive 390 Husqvarna
    Gorman is hard to beat. I remember when it was wide open. No forest service closures etc. You could ride up to the mountain and come down the other side. There was an intense dry wash coming down and then you would follow the edge of the river. Would get so close to it at times one would use their other hand to keep from hitting the handlebar. I still try to get there every so often. Looks like a nice late seventies early eighties IT your son is riding?
  16. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    84 IT200. My dad bought it new, switched to a KDX and sold it to me when i was a teenager. Rode it until it started to catch a ring in a port and it sat for a dozen years or so.
    Refurbished it with an engine from an 85 I picked up dirt cheap and it's back in action. Now I have a complete parts bike to keep it going. It's actually the wife ride, but the Marine and I snuck out while she was out of town.
    I fondly remember those days too. We'd follow the creek down to the gold mine, take the dirt way up Alamo, etc. The big walls were fun too.
  17. justintendo klotz super techniplate junkie
    i found a q7 needle jet so ill try taking the bike out tomorrow and see how it does..really makes you appreciate how easy the lectron is to dial in!
  18. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Here is the response from Amsoil a question I askedon their website.
    question;
    My question is which mix oil is best to use with
    100AV low lead fuel also known as AV gas which is sold at local airports?
    Is any of your mix oils not compatible with certain kind of fuel?
    Hi Doug
    All the AMSOIL 2-cycle oils are compatible with all gasoline based fuels
    including avgas and up to 15% ethanol pump gasolines. However AMSOIL is not
    compatible with the exotic fuels such as nitro methane and such that are not
    gasoline based. I would not recommend using E85 in any 2-cycle engine.
    For the highest performance oil for racing use the Dominator. For stock /
    non-racing the Interceptor would be the better choice (with power-valve
    engines the interceptor will do a better job of keeping them clean.
    PowerKord and justintendo like this.
  19. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    That's good information Doug!
  20. justintendo klotz super techniplate junkie
    one of the reasons i always used super techniplate is that is mixes with everything. never had a concern with it mixing with alcohol (ethanol)...
    https://www.klotzlube.com/Ecommerce/site/content/PDFs/TECH/KL-100-Tech-Sheet.pdf
    blends with e85, alcohol, nitromethane, etc...
    im also a big fan of amsoil products but ive run klotz too long with good results
    i used to hang out with some micro sprint guys...all the micros used 250cc 2 stroke engines burning alcohol. well over half the field all ran klotz benol. benol is really dirty but great protection and mixes with anything. very few oil manufacturers will come out and say their oil works with alcohol or anything other than pure gasoline...
    one thing is for sure ill be breathing castor tomorrow, lol. braap!
    lankydoug likes this.
