Rebuilding a1985 cr500... got some questions
Discussion in 'Vintage/Left Kickers' started by TahoeHusky, Mar 30, 2015.
  1. TahoeHusky Husqvarna
    Lake Tahoe California
    1985 Husqvarna 500CR
    2003 Honda CR125 , 2000 Honda CR80
    Another question. I have new front brake pads for this bike. But have yet to install them. How do you remove the pin? Ive searched around and have found no instructions.
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i try to give a two stroke larger doses of throttle sometimes to avoid too much "streetbike" style throttling. being a gear tall will help, or worst case ill pull the clutch in a give it a little rev. usually its very easy to incorporate this into riding. when jetted right its not too big a deal, just try to vary the throttle.
    TahoeHusky and oldbikedude like this.
  3. TahoeHusky Husqvarna
    Thats what I was guessing. This isnt my first two stroke and the clutch in and rev and running a gear taller is pretty much what I was already doing. varying throttle is always what ive gone by. Thanks for all the info. Any info on the brake question I asked above though?
  4. justintendo klotz super techniplate junkie
    cant remember the single piston setup offhand, they are in my bins..let me go check.
    looks to me like the pin just pushes back out from the inside out. i dont see a retaining pin that needs removed. i only have one caliper here tho, the rest are at my big garage
  5. TahoeHusky Husqvarna
    Ok. There is only one pin that looks like it needs to be removed. I tried pulling it out with pliers but i dont want to force it until i know its the proper way.
  6. justintendo klotz super techniplate junkie
    probably have to tap outwards with a punch. sometimes on the later brembo there is a little hairpin that comes out before you tap it out..
  7. TahoeHusky Husqvarna
    Ok so the one long gold retaining pin that goes through the holes in the pads is just pressed in? When I get home I will try and remove it. From what I can tell after that pin coms out there is a little piece on top of the pads and once the pins out that will come out then the pads.
  8. TahoeHusky Husqvarna
    Just a little pic from my last ride. LED bar works great. 20150625_185631.jpg
  9. TahoeHusky Husqvarna
    Got the front pads changed and bled the caliper accordingly. Brakes work a bit better now. Bout to take er for a ride. Ill let yall know how it goes.
  10. TahoeHusky Husqvarna
    Clutch went out on my ride. Just lost all feeling. It was on its way out anyway. New plates in the mail.
  11. justintendo klotz super techniplate junkie
    better check it out in there....i really like the ones i got that upgraded to steel plates
  12. TahoeHusky Husqvarna
    I got new gaskets too so I will be tearing into it soon. I couldnt find any aftermarket plates for my bike on husqvarna-parts and didnt want to shop overseas so I settled for a new-used set from ebay just to get me riding again. I did buy new springs and clutch hub c clip and other misc clutch parts from husqvarna-parts. Its funny though, the clutch always felt hoppy and messed up but it worked and I rode the bike probably 50+ short rides right from my house since Ive owned it and its been fine, then when I take it on an actual like 15 mile trail ride it decides to break. But thats the fun of dirtbikes i guess!
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I just did a fast desert ride last weekend and then noticed yesterday the chain clip is missing? that could have been a fun dirt bike experience!
  14. justintendo klotz super techniplate junkie
    or expensive....or painful.....or both
  15. TahoeHusky Husqvarna
    Thats sketchy!
  16. oldbikedude Husqvarna
    Honey Brook Pa.
    I call that a lucky ride.
  17. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
  18. TahoeHusky Husqvarna
    It is on miller lake road which is the pavement/gnarly dirt road that accesses the rubicon jeep trail in Lake Tahoe California.
  19. 2premo Husqvarna
    Northern NV
    are you in Tahoma, only access i recall is McKinney Rubicon
  20. TahoeHusky Husqvarna
    Yes I am in Tahoma. I ride illegally for a block or two on the road before I hit the OHV.
