restoring a Up-Tite 87 250 XC...
Discussion in 'Vintage Restoration Projects' started by everfree, Jan 26, 2016.
  1. oldbikedude Husqvarna
    Honey Brook Pa.
    The black on the cases look awesome! Better than stock! I might like the cyl & head both silver. Not sure
  2. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    I agree, ...can't go wrong with the cases color. They did turn out nice.
    I almost did the cyl and head both in silver.
    We'll see how it looks when its all together in the bike. If it looks like crap, I'll say "...won't do that again" !
  3. everfree Husqvarna
    Bend, Oregon
    Never thought of that. Might be interesting.
  4. everfree Husqvarna
    Bend, Oregon
    I almost went this far... but thought a solid color would be too much. But I do like the Works bikes of the old days.
    I'm trying for a "Works" look, but like Husky might have done, not Honda!
    Timppa R likes this.
  5. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Maybe the yellow that could work on rims for huskies is the yellow rim color you see on the factory Suzukis. Its really more
    like a Swedish yellow and I think it would look good on a husky.
  6. oldbikedude Husqvarna
    Honey Brook Pa.
    I do love the blue/yellow sweeds. Look at some of dartyppyt's bikes. He has some tastefully done use of colors on his bikes. I'm sure your motor will look great as well.
    everfree likes this.
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I did the head on the 400 candy apple red...
  8. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    a tip for fitting pistons etc. fit the piston into the barrel on the bench so you are 100% sure the rings are in the right spot then slip the piston half out of the barrel and drop it over the studs then pop the pin in through the piston and slip the clip in. slide the barrel down onto the cases all done. you need to support the back of the piston with rags to allow the pin to be knocked in.
  9. everfree Husqvarna
    Bend, Oregon
    Candy apple red? That one I have to see!
  10. everfree Husqvarna
    Bend, Oregon
    Good one. I thought that might work and I was just about to do that when I got the piston to slide up. I remember that for next time.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I have a rebuild thread on the 400 here it has a nice pic of the red head....if I knew how to grab a link I would drop it in
  12. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    search wr400 under suprize and it pops up...how good is that
  13. everfree Husqvarna
    Bend, Oregon
    ...and Bob's your Uncle... suprize's Red Head 400:
  14. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    also note the horsepower adding red clutch actuation arm.....
    everfree and justintendo like this.
  15. everfree Husqvarna
    Bend, Oregon
    OK, I'm back on the '87 250. Sorry for the delay... some vacation and other bikes got in the way ... :-)
    I've been waiting on the 250 primary cover to be repaired... it took forever. I finally got it back. Now I can finish the motor rebuild.
    The previous owner had kicked the hell out of bike and cracked a hole in the case. It had to be welded and formed again around the kicker stop. And the broken kicker stop screw had to be drilled out and tapped. See below in upper right where temporary bolt is in place
    stripped aluminum cover before ceramic coating...
    close up of the kicker stop fix and temp bolt
    inside view of fix...
  16. everfree Husqvarna
    Bend, Oregon
    Just got the cover back from the coating guys today..
    The coating guys did a great job on the cover and other bits. The Cerakote color is Sniper Gray like the engine cases.
    I also had them coat the water pump guard and the brake reserviour guard.
    Looking good I think. You can't even tell it was repaired.
  17. oldbikedude Husqvarna
    Honey Brook Pa.
    Case repair & coating looks great.
  18. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    phils kick bumpers fit well, hold up and even come with a new ss screw:thumbsup:
    oldbikedude likes this.
  19. everfree Husqvarna
    Bend, Oregon
    Yep, you're right. I just happen to have one.
    Here you go... Phillip's rubber baby buggy bumper installed...
    84scrambler and oldbikedude like this.
  20. everfree Husqvarna
    Bend, Oregon
    I had to pause today and clean the garage / shop. After months and months of working on bikes and doing this 250 resto, the floor was grimy and crap was everywhere.
    I'm sure you guys know what I mean! I degreased the floor and now it looks like new.
    6 Huskys all in a row. Foreground is the 87 250 awaiting the motor, next are the two 86 430 Autos, an '88 430, a '14 144 CR, and a '12 310.
    I'm rebuilding the forks on the 86 430 Auto after installing new sprockets, new chain, new rollers, fixing an exhaust mount, and installing the overflow bottle...
    I decided to pull the front rotor and de-rust it... I hate rust! I could only soak 1/2 of it at a time. What a difference! That Evap-o-rust is great stuff.
    oldbikedude and 86 400 XC like this.
