restoring a Up-Tite 87 250 XC...
Discussion in 'Vintage Restoration Projects' started by everfree, Jan 26, 2016.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    whatever the swedes used on those cases is excellent! when i encounter a set of cases with a ton of paint worn off, it makes you realize how long these engines can last!
    everfree and oldbikedude like this.
  2. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    Ha, Ha, yeah, starting a 430 on the first kick is good especially right after a rebuild! Great work.
    My 430's trained me how not to start them... the hard way!
  3. everfree Husqvarna
    Bend, Oregon
    I pulled apart the 87 250 forks... the oil wasn't that bad considering.
    Just for comparison, here's my 87 fork leg w/ damping spindle (top) and 88 fork leg w/ damping spindle (lower).
    Notice the differences in damping components.
    The yellow spring and spacer are from the 87 250 I'm restoring. Does the yellow mean a certain spring rate?
    That's 70mm of spacer with a stock length spring! What does that tell you about who owned the bike and how he rode?
  4. justintendo klotz super techniplate junkie
    ive seen those spacers and yellow springs in an 87 xc430
  5. oldbikedude Husqvarna
    Honey Brook Pa.
    I'm not sure what the yellow means. Does the yellow spring look like it was cut down or does the end look "worked on"?
  6. everfree Husqvarna
    Bend, Oregon
    Didn't appear to be worked on. The yellow 250 springs are the same length as my stock 87 430 springs. When you drop them into the fork tubes they come to the top, so the haven't been cut.
  7. everfree Husqvarna
    Bend, Oregon
    Hmm. Specific to the XC model?
  8. everfree Husqvarna
    Bend, Oregon
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    Someone must know the spring rate...I however do not.
    everfree likes this.
  10. everfree Husqvarna
    Bend, Oregon
    I counted the coils on my fork springs:
    yellow springs: 48 coils
    green springs: 51 coils
    Both are the same length.
    Question: Fewer coils = higher spring rate?
  11. Bodger Husqvarna
    wr400 enduro 1986
    triumphs, bsas, yam tt500
    Jig up a test instead with a bathroom scale, you/we have no idea from here if the material is the same dimension and spec.Stock metal from a metal supplier is usually color coded so I am suspect that they used color coding on springs perhaps to indicate different composition/temper? when the size and coil count is readily seen.
    hmmmm.
    But if everything except coil count were the same fewer coils would give less deflection for the same size riderbutt.
    YMWV.
    Now my head hurts trying to think about it.......:thinking:
    oldbikedude likes this.
  12. oldbikedude Husqvarna
    Honey Brook Pa.
    Wouldn't Andy from HVA-Factory know the rate of the springs he sells?
    Bodger likes this.
  13. justintendo klotz super techniplate junkie
    if the coil wire is same diameter, then yes, more coils is softer spring.
    Bodger likes this.
  14. 84scrambler Husqvarna
    mid Florida
    Everfree, start on the plastics with a pocket knife. Pull the knife towards you with blade edge straight down , then dry sand with 150 then 180 grit, and then go to wet sand start with 220 then 400 then hit it with some 1000 and then polish it out with Maguiars cleaner wax. Its a real time consuming p.i.t.a. but it works if you are willing to put in the elbow grease.
    I think your gonna love the 250 stroker motor it has long winded power in a perfectly spaced transmission.
    Kam1 and justintendo like this.
  15. everfree Husqvarna
    Bend, Oregon
    84scrambler, thanks for the procedure. This is what I was thinking. I'll give it a shot and record the progress.
    With all the white plastic on these LC Swedes, all my Huskys could use this!
    I wonder if someone makes a plastic protector spray? To keep the plastic nice... at least for awhile.
    Yep, can't wait to get the 250 running. Long-winded and perfectly spaced tranny sounds great for high speed riding.
    With the porting / polishing that George did and all the other racing bits it has, I think I'll keep it setup for desert riding.
    I don't want to waste its potential by setting it up for the woods.
    I'm starting to clean the engine cases and frame for powder coating.
  16. oldbikedude Husqvarna
    Honey Brook Pa.
    everfree and Bodger like this.
  17. justintendo klotz super techniplate junkie
    once you have it worked to a decent sheen again, it will stay ok for a good while. i use "dolphinite" uv protector which is kind of like a mild armor all, but just leaves things looking new instead of "armor-alled"
  18. everfree Husqvarna
    Bend, Oregon
    I added an old-school Hi-Flite seat.
    This Hi-Flite seat even has a stitched on logo! I don't think they do that anymore.
    Here's the old zebra seat. I know it was popular in the late 80's, but I'm not a fan.
    the new Hi-Flite:
  19. justintendo klotz super techniplate junkie
    looks good!
    hopefully that kicker bump stop hasnt been like that too long..
  20. everfree Husqvarna
    Bend, Oregon
    Thanks.
    Yeah, the case is bent and cracked at the kicker bump stop. I'm going to have the machine shop pound it out and weld it.
    Hopefully we can get it looking nice.
