Ricochet Skidplate
Discussion in 'TR650' started by Hansi, Apr 10, 2013.
  1. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    I brought some stuff called Motospray Spray on Sound Deadener & sprayed the inside of the plate. It has reduced the tinny noise quite a lot.
    Just need to buy a radiator guard. Has anyone installed one of these? Please attach pics & details. Cheers
  2. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    This is a must for me, and I haven't found one available yet. If the radiator on the Husky is anything like the KTM oil cooler on my Bonnie, I'll be replacing a few of them if I don't get a guard. :banghead:
  3. mario33 Husqvarna
    Warsaw, Poland
    Problem is that Terra's raised front fender makes it very hard to fit a radiator guard. If and only if it can be moved that bit away (spacers on mounts ?), R&G Racing proposal for Strada might serve the purpose:
    http://www.rg-racing.com/browseBike/Husqvarna/TR650_Strada/2012/RAD0138BK.aspx
  4. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    I emailed R&G to ascertain the suitabilty of using their guard on a Terra due to the small clearance. They replied saying that their product is about 3mm proud of the radiator. I was thinking of using a heat gun to heat the mudguard and bend it away to increase the gap slightly. It's black so you shouldn't see a burn mark.
    bboffroad also sell a guard but it appears that they have photographed it without the bikes mudguard so it's hard to determine if their's going to be an issue. I prefer the R&G product as it is black.
    http://www.bboffroad.com.au/tr_650_terra.htm
    mario33 likes this.
  5. Chuffa Husqvarna
    Perth, West Australia
    TR650
    XT250
    I'm not sure how to link to it, but I posted the details of my B&B radiator guard in TR650 Mods. Post #191. With pics..
    B&B provide spacers to change the angle of the front fender. I've had no problems with clearance nor overheating.
    Edit... 10mm width on cutout slots.
    mario33 likes this.
  6. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
  7. Coffee CH Owner
    Click on the post #, then a window pops up with the link already highlighted.
    Control-c on a PC will copy it.
    Command-c on a mac will copy it.
    Chuffa likes this.
  8. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    Attached some Aircraft (belly) rubber to my plate..tried to cover it all in one sheet but because of the tight bends of the aluminum i couldnt get it to fit right, so i used peices....works pretty good..not quite as quite as having no plate but definitly works pretty good on absorbing engine noise. CAM00120.jpg CAM00121.jpg
  9. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Anybody tried tool dip? Not sure if it can handle the head, but it would be super easy and water resistant.
  10. Eka Husqvarna
    Costa del Sol, Spain
    TR 650 Terra
    BMW HP2 Sport, HP2 Megamoto, K1600GT
    I wish i would had skidplate already. My brand new bike has just done 400 km and i noticed that cluch cover was a little oily. Stone had hit it and it is sweating oil a bit.
  11. TerraCzar Husqvarna
    Ramona, CA
    2013 TR650 Terra
    Maybe try to tighten the clutch cover bolts? Or is it leaking at the stone impact? I would imagine the clutch covers are fairly inexpensive, so maybe swap out on next oil change.
  12. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Well that sucks !:thumbsdown: How bad?? What if you clean it up and use some JB Weld High Heat? Might work.:thinking:
    FabOneUp likes this.
  13. Eka Husqvarna
    TR 650 Terra
    Yes, it was leaking from impact. Not much, but anyway. I had that kind of epoxy putty and already put it yesterday, but there was not mention about heat resistant... i think. I believe it doesn't get too hot for it anyway. I cleaned surface from oil with acetone first and put that epoxy putty there. Not pretty, but i guess it will work for the first service. I have to travell off for few weeks and hopefully i get it to first service before that and let them to change it with the same trouble. I hope they get the part while that...
  14. krussell Strada Adventurer
    Portland, OR
    Strada (for sale)
    K1600 / Super Tenere
    Appears to be about $65
  15. Thomas Riser Husqvarna
    Portland Oregon
    2013 Terra 650
    CR 250
    Ordering mine today!! Don't know if I should just get it stock, or gun metal grey.
