Round two of the "other" carb types - Lectron
Discussion in 'EFI/carb' started by Motosportz, Dec 18, 2012.
  1. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Well I'm not going to claim that I can fill Walt's shoes, but I can tell you that the screws that I have seen are 6-32X1/2". I like metric threads for small fasteners and have been looking at tapping for them. The 6-32 thread though is just a bit larger (.005") than tap drill size for 4mm X .70mm, which is a common metric size for carb screws. Probably would work just fine though.
  2. Xcuvator Husqvarna
    Scholls Oregon
    yes
    That's interesting Doug, because the TMX that came on my 04 WR250 are M4 X .70 and I don't recall seeing standard threads on any Japanese carb. :excuseme:
  3. john01 Husqvarna
    Powhatan VA
    Think he means "corse" threads and not "fine" threads. I would think they would be metric for sure.
  4. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    If they are M5, they can be mistaken for 10-32, as they're practically interchangeable.
  5. Motosportz CH Sponsor
    I'll ask Kevin if we can get these with metric allens in the future.
    Dirtdame and jmetteer like this.
  6. guscycle Husqvarna
    Florida
    '99 Husky CR250, '07 Husky WR125,
    '10 Husky SMR450, '98 Husky Scooter
    ..I was able to get 4mm screws at Home Depot...they were black allen heads with a 16 mm length.They also had the 4mm lock and flat washers. Thing is I don't know if they are available at all Home Depots. SCREW.JPG
  7. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    The bowl screws will be M5 then. Like I said, they are practically interchangeable.
  8. wallybean Mini-Sponsor
    Montana
    I just replaced the top screws on my new Lectron 38(thanks Kelly and Kevin for the quick replacement). They are 6-32 machine screws, not metric. I would think tapping them out to an M4 would be easy if you want to be consistant with your outdated/archaic standard carbs. :D Interesting as my initial 38mm needed to be leaned out only 1/2 turn. This one took 1 1/4 turns to make it completely crisp. The shorter spigot on the engine side took all the stress out of mounting as the boot no longer rubs on the shock. Also the adjustments that Kevin made to the carb holder netted about 3/4" of slack and by adjusting the top adjustment all the way out I was able to re-route the stock cable where I had it before with the stock carb. It is snug to be sure and I zip tied it in place so it can't pull it out of the carb. Still looking forward to the longer cable so I can route it better and no worries about pulling it out/stuck throttle.
  9. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    The news of the Lectrons greatness would seem to have so far missed the UK shores so outdated/archaic carb sales have been going well :D
    George from this forum bought a TMXX from me, a friend bought a PWK for his nephews 144 KX and one sold from eBay (not a lot of money:(lol)
    My old Lectron now resides on a friends Husky and the space where a carb is ment to live on the WB165 is just rags stuffed into the boots :(
    So after waiting 25 day for a new one to pop through the mail and nothing appearing it looks like I will have to order another one and will have to use a Tmxx for now or pull the 37mm from the 144:cry:
    On the plus side the swelling around my broken toe has shrunk enough to get a pair of boots on in reasonable comfort and the bruising is on the way out :banana:
  10. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I have a Lectron on the way and in anticipation, I ordered a KTM throttle cable. Actually a Motion Pro 10-0056 which supposedly fits all KTM 2 strokes from 99-12 . Everyone says they are longer but don't mention a specific year or model. My Motion Pro is 3" shorter than the Husky cable. Unfortunately, I found out after I removed the Husky one. What am I missing? The Mikuni gods don't want me to have a Lectron is my guess.
    454x likes this.
  11. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    After doing some reading in this thread, it is the consensus that the stock cable is "tight" even for the stock carb. Mine is anything but tight, I wonder if a longer cable got put on mine somehow at the dealership. :excuseme:
  12. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Got a new KTM one on the bench awaiting fitment and its 2" longer than the Husky item, BUT this is the 125 husky and I dont know if the other Huskys use the same cable !!
  13. Motosportz CH Sponsor
    Cool then you should have zero issues.
  14. Xcuvator Husqvarna
    Scholls Oregon
    yes
    It is my understanding that staring in 09 the 125 cables grew 2".
  15. Steve-oh Husqvarna
    Lethbridge, Alberta
    2010 WR 300
    04RM250, 05XR100,07PW80,41 Harley
    Exactly, my stock cable is plenty long, no worries here. Fits good. The only thing I'am worried about is the cable popping out of the top of the carb where it fits into the adjuster. It's a pretty short sleeve that the cable fits into compared to the Mikunii.
  16. TROFFER88 Husqvarna
    Camas Wa
    ^^^^^ use the supplied boot and a zip tie
    Motosportz and 454x like this.
  17. duey Husqvarna
    2009 wr 250
    2003 ktm xc 2008 ktm 250 sx
    Bingo motion pro simple solution for such a great benefit of carb.only time well tell if it's the jetting solution
  18. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Got my Lectron today. Thanks, Kelly. Just finished installing it. It definitely was a bit more work than removing and reinstalling the TMXX. No matter how hard I tried, I couldn't get it to fit without doing more work. I had to remove the side panels, bolts holding the silencer, 2 bottom bolts of the subframe and swivel the subframe up. I also had too much play in the throttle cable even with both adjusters all the way out. I had to use the Mikuni elbow to take up the slack. I didn't adjust the needle because my bike's TMXX jetting was richer than everybody else here. It started on the 3rd kick and idle seemed to be right. The bike started on the first kick this morning with the TMXX after sitting for 2 weeks. :rolleyes: It was too late to drive it around the neighborhood. I'm going riding tomorrow and going to have a hard time sleeping. [IMG]
  19. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I haven't gotten around to installing my Lectron yet. I've been sorta busy. The carb is just sitting on the kitchen table like some modern art centerpiece.:rolleyes:
    Long_Stroke and wallybean like this.
  20. wallybean Mini-Sponsor
    Montana
    I had mine on my desk at work for a couple days at first and got some interesting comments from the guys.
    Xcuvator likes this.
