Round two of the "other" carb types - Lectron
Discussion in 'EFI/carb' started by Motosportz, Dec 18, 2012.
  1. Watky Husqvarna
    Wr150
    Has there been a dyno comparison chart uploaded comparing the Lectron to the stock carb with RM needle for HP, torque & AF ratio? I've gone through the pages but may have missed it.
  2. Motosportz CH Sponsor
    thanks for doing this.
  3. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    Got mine dialed in now,(09 300) went another 3/4 lean for a total of 1 1/4 I think:confused: Also my power jet was out 1 1/2, so turned that back 1/4 also. Now this thing screams!!! Can't wait for next weekend's HS. Not only is it buttery smooth but the revs pick up sooo nice & you can still stay a gear or two high to tractor thru whatever is in your way. Don't even feel the need to try another 1/4 leaner, so thanks again all.
  4. WVdag Husqvarna
    Smithville, West Virginia
    2007 WR250 W/300 kit, 2013 CR125
    1987 Harley FXLR 10th year edition
    Amen brother, I agree especially with the gear higher. Question for anyone, is there a trick to getting the slide back in place without having to stick a finger in and guide the needle in place? Just wandering if I was missing something.
    Dave
  5. Motosportz CH Sponsor
    No, not that i have found, tight little buggers huh.
  6. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Just giggle the slide up and down, it can be a pain but mine always drops in unlike the older version as that was a fight evert time.
  7. TROFFER88 Husqvarna
    Camas Wa
    Collapse the spring a little to take the tension off the needle and they slide in easier
  8. Vinduro Husqvarna
    Mississippi
    Be sure not to unseat the needle as it will run rich off idle. If you push down when installing the needle holder may hang on edge of slide. It happened a couple times to me before I figured it out.
    boisedave likes this.
  9. boisedave Husqvarna
    Boise, Idaho
    Me too!!!
    I thought I was loosing my mind. These carbs are super sensitive to the needle position -- I now only move forward if the needle slides in smooth, otherewise I am not confident its set correctly.
    Another note too -- Last ride or two -- carb worked great, but seemed a tad rich. Here is the drill I went to get a clean running carb:
    Leaned out the needle in 1/2 turn increments until the carb would bog when I grabbed a handful of throttle [just did this on the stand]. Took it another 1/2 turn and [shockingly] it just acted a bit leaner. You know its getting leaner because you can slow the idle down.
    So -- with the needle 1/2 turn too lean; I went back a quarter turn richer. This cured the bog and was lean as I could get it with still a crisp pull. This worked great for me. My bike doesn't like the power jet. I have it open only about 1/4 to 1/2 turn. Any more than that and it sputters. Just FYI.
  10. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Update on my review. After 2 enduros, a team race in frame deep mud, and a rocky Missouri harescramble, I've got probably 10-15 hours with the 38mm lectron on the wr300. It took some getting used to, but a change from 13/48 to 14/48 gearing was partly at fault. Part of my problems getting used to it was the sections I used to click into third and grunt through. With the lectron it wanted to climb up the revs making it a bear in the tight stuff. The taller gearing made that worse as now that 3rd gear through rough creek beds turned into too fast for my suspension to keep smooth. Now that I've adapted to it, it really is an amazing setup. A bit wild, yes, but it's completely manageable with a bit more finesse. I'm holding onto my PWK to put back on for when I go to sell it for a new 300 (or I might just say damn the contingency and keep this one forever). The Lectron is just that good.
    Fuel mileage, I maintain is no better than before in my application. I don't think it's any worse than what a proper jetting would be, but I do need to pit around the hour mark of a harescramble to add a gallon of go juice. And on the enduros I have been topping of at all available gas stops.
    Xcuvator, lankydoug and Motosportz like this.
  11. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I'm in Utah for work and brought my bike with me. It's about 900' where I usually ride in TN. I'm in Moab and only had to adjust the powerjet a 1/4 turn leaner. Carb is working perfect. There were a few times where I should have stalled but the engine would keep on lugging.
    Motosportz, 454x, Blakelpd5 and 2 others like this.
  12. Motosportz CH Sponsor
    :thumbsup:
    rode my 165 at a race this weekend where elevation was 3700-4300 and i usually ride at 200-1500. 1/4 turn leaner on the PJ, perfect all day with amazing pulling power in 6th in deep silt.
  13. street2dirt Husqvarna
    BMW G650X
    Wow, mine is really really good. Had a HS yesterday & it did everything it was supposed to. Still gonna go back through the steps again, I may be a 1/4 lean. Now my only problem is if I sell the bike, do I leave it on??
  14. msmith345 Husqvarna
    Shawnee, KS
    That's why my Keihin is setting on the shelf. If the time comes that I sell the bike the Lectron will go on my next bike. My dealer was telling me he wanted to try one, but I won't even pull it off to try on my brother's WR125, because I don't want to risk having to ride mine without it again.
  15. Motosportz CH Sponsor
    Yep.
  16. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    454x, Xcuvator and Motosportz like this.
  17. firebolter Husqvarna
    Annapolis
    06SM610
    13TE300Berg,07KTM525EXC,13 HusWR165
    Question for you guys. I have mine set up and it runs good, but is spooging a little more than usual and my fuel consumption is WAY more than my carb'd counterparts. I am on a 300 Berg and they are on 300GG. I have a 36mm Lectron.
    Example, this last weekend at Hatfield's Buff Mtn, I used 1.4 gallons at fill up at lunch where as my buddies on GG300's were taking 1.0 or 1.1.
    I still need to pull the plug and look at it, but seems to be a little rich, but pulls good. I need to call Kevin and see how I can dial it in a little better as I should not be using that much more fuel. We are all riding the same pace in a group so throttle usage is similar.
    Second day I took 1.7 gal and they took about 1.3, so consistent difference in fuel consumption for the 2 days. Again the bike runs good, pulls good just has a little flat spot in the mid to top transition that "seems" very much like when the plug is loaded up from alot of very small throttle use and then you have to "clean" the plug out when you hit the open stuff.....
    The only adjustment I have made since I got the carb is, after the first 4 hours, I leaned the needle 3 clicks (3/4 of a turn) cause it was spoogin like a mo fo as delivered. Ran great, just was really rich. I mean I was getting spooge out of the pipe/silencer connector area. Since leaning the needle 3 clicks, that has subsided to a minimum and now I just get some out of the can which is ~normal I guess even with a properly jetted carb. I am wondering if maybe my Top end adjustment (external screw adjuster) is too rich and that could be causing the spooge when I do go WFO and and that nid to top "transition" is due to the top end being set too rich.
  18. Motosportz CH Sponsor
    where is your PJ set at? Hoe many turns out. To much will cause bad MPG. you might need my new rod...
    http://www.cafehusky.com/threads/lectron-125-144-165-custom-rods-coming.32268/
    The PJ is supposed to be a fine tuner. If you are running to much you need this rod I can up with that is richer on top so you can run your PJ back to like 1 turn out.
    Let me know.
    Kelly
    Mz
  19. TROFFER88 Husqvarna
    Camas Wa
    I got 31MPG with the Lectron at China Hat ISDE last weekend
    454x, wallybean and Xcuvator like this.
  20. Motosportz CH Sponsor
    250GG thanks for the info. I think I got just shy of that (Guess) which i was thrilled about. I think i get about 3-7 MPG better with the Lectron.
