Searching for low end 82 CR250
Discussion in 'Vintage/Left Kickers' started by Eurofreak, Jan 24, 2017.
  1. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    '76MR250 '83IT250 '84 IT490 '69CT70
    Sexy looking bike. Is that tank original? or is a restoration with a decal?
  2. Eurofreak Husqvarna
    Western NY
    1986 TE 510, 1982 CR250, 2008 WR250
    70's Triumph , Bultaco , Maico, etc
    Thanks!
    Restore with a shiny decal. Not perfect but very pretty.
    There's a Pro Circuit pipe on fleabay an Asch pipe. Don't know that would do much for the low end.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
    Just ride it ditto/\ /\ said above. It's not complicated. You will get use to it, I did. If I did you can too.
    You will like using the power coming out of the turns wicking it to steer it. Trust me you will like the power.
  4. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    There is more to it than just the pipe. You can use a WR chamber to accomplish what you would to put 20mm into the header of the CR pipe. I would just work with a 82 WR sleeve pressed into the CR cylinder or I have an 82 WR cylinder that I determined the CR ports in the base gasket surface can easily be added because the surface to cut them into is actually thin wall.
    The 250 that got the power valve was also a long stroke engine. You will not really get usable low end in the CR without sacrificing top end. If you plan to race motocross, you can live without the low end. I know it is no fun screaming a 250 like a 125 but that is what Husqvarna left us with until the came out with the long stroke and the powervalve.
    Husqvarna focus in 1980 -1984ish was the 500 class. The 250CR went down in popularity because the Japanese 250s had near ideal engines, turned sharper, and were less expensive to boot.
  5. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    ....and had 1 shocker...they were all the rage
  6. Eurofreak Husqvarna
    Western NY
    I'm not much of a motocrosser. I'll try the vintage tracks- I like grass tracks. I will play with the jetting first and see what happens. I can also adjust timing a little. It feels great in the woods. Definitely will work for hare scrambles.
  7. darren7878 Husqvarna
    79 CR390 and 84 CR250
    81 Maico, 79 Kawasaki, 88 Honda
    before changing the jetting, try a brand new stock idle jet in there. They do fur up and that those are the symptoms when they have........
    Eurofreak likes this.
  8. Bigbill Husqvarna
    '83 250wr
    0 right now
    Didn't the NETRA harescramble guys run cr's? Weren't the cr's more popular in the woods before the kdx200/220? I know the really fast guys used the kdx's later on. The kantoon 200 is popular today.
  9. Eurofreak Husqvarna
    Western NY
    Don't know about NETRA. I'll check with Drew and see if he's got any advice. Time to see what's in the carb.
  10. Bigbill Husqvarna
    '83 250wr
    0 right now
    Look at the tech specs posted in my husqvarna 250 XC post there's two different carb setups one for a cr/XC and another for the wr. They change the inner parts on the wr maybe to calm the woods bike down?
  11. jimspac Husqvarna
    Connecticut
    I am sure there are 80's vintage motocross bikes in the NETRA vintage hare scrambles. It would be a good place to run the 86 KX250 I have
  12. Eurofreak Husqvarna
    Western NY
    hard to read the chart
    Main difference is needle jet and main jet needle. Forgive my ignorance- what is the needle jet and how do you change it?
    Yeah Jim, I'm sure the motocrossers can be raced in the H.S. The bike handles great in the woods. Suspension works well slow and fast. It's the tight slow stuff I want to work on.
    So...I pulled apart the carb. It's nice and clean. The needle position was set in #2 position (second from bottom groove).
    The main jet is a 430- '81 Cr's had a 430, '82 specs a 410 for the CR and WR.
    The pilot is only a #40- should be a #45. that would explain the low end bog along with the needle in the higher position.
    Air screw was completely screwed in!
    No fuel then too much fuel. I'll order a WR needle as well as a new couple of mains and a new pilot.
  13. Bigbill Husqvarna
    '83 250wr
    0 right now
    The needle jet is the verticle tube that the needle goes up and down in. Remove the main jet and the needle jet pushed up towards the direction of the sleeve when it comes out.
  14. Eurofreak Husqvarna
    Western NY
    Thanks Bill!
  15. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    Air screw should be between 1 and 2.5 out, if the pilot is lean at 1.5 out you will get a surging engine at idle but you will need to warm the bike up and take it for a ride the surging will be worse when returning to idle from a high speed run.i had a 35 pilot and got surging at idle but would disappear with the air screw all the way in, went up to a 38 and set air screw at 1.5 never got a bog as such just surging at idle.
  16. Bigbill Husqvarna
    '83 250wr
    0 right now
    I go between 1/2 to 1 1/2 turn out I prefer to balance it at 1 turn out. This way we have half a turn to tweek it if needed after she's close. Remember we can get the first 90% of the jetting. The last 10% made me bald. I start out with the needle in the third groove.
  17. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Use base gaskets to set squish at .040-.045".
    fran...k. likes this.
  18. Eurofreak Husqvarna
    Western NY
    What will setting the squish do? Is that the stock setting?
  19. jimspac Husqvarna
    Connecticut
    Helps to boost compression ratio if you really need it. Not so much on the East coast where the trees and rocks are somewhat closer together
  20. Bigbill Husqvarna
    '83 250wr
    0 right now
    Low end is what your looking for the 11t front sprocket will give you a lower speed crawl. You will be n third gear more on the trails. You could get a wr cylinder and jet it for a wr.
