single seat registration
Discussion in 'TR650' started by Moff69, Aug 5, 2014.
  1. glitch_oz Husqvarna
    AUS
    Strada
    State Farm...that's the one! Compared to the mobs over here, found them a refreshing breeze to deal with....and one CAN actually wheel+deal with them...at least to a point.
    Different over here!! Don't like me charging you full whack on both your bikes? (even though you can only ride one at a time!)
    Shove off then....NEXT!
    Same goes for the compulsory rego/ insurance...2 bikes = 2x full premiums! Same for the full comp insurance....and there's around $2000/year for 2 bikes registered and insured.
  2. SpittingCobra Husqvarna
    Albany Creek, Brisbane, Australia
    Tr650 Strada
    KLX400
    Mine is single rego, no change to the seat, just removed rear footpegs, done by the shop from new. This crap about modifying seat length is ridiculous, as if everyone's arse is the same size! You could argue that, as it is an adventure bike designed to handle rough terrain, you could be severely injured by modifying the seat from the original design. If a certifier gives you hassles, just go to another certifier.
    Moff69 likes this.
  3. Tom Ruxton Husqvarna
    Suzuk.Yamaha.Honda.BSA
    No need to modify seat anymore. just declare that it meets the standard.
    Tom R
  4. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    Many dirt bikes have long seats and can get single seat reg as they are proscribed as a single seat by the manufacturer ( importer?). If it is fitted with passanger footpegs std then default dual seat reg appently. The Seat length was still in the legislation when I made mine single seat in 2013. That was in Townsville and there are only 3 certificate issuers for motorcycles and all of them insisted on the the seat length requirement. They did let me get away with the front bit saying it wasn't strictly a part of something that you could sit on. It may have changed since then. Sally's KTM I didn't need to check as the front and rear seats are separate and I just took the passenger one off and the front was way shorter than 50cm.
    Thanks Glitz for the more complete explanation.
    " you could be injured by modifying you seat"... I have been changing seats ( and everything else) on motorcycles for over 40 years and never even seen a single injury from a changed seat. Modifying almost everything else is more of a problem than modding you seat.
  5. Tom Ruxton Husqvarna
    You don't have to get a certificate anymore.
    listen to what I am telling you. just front up at the registry put your hand on your heart and swear that it meets the regulation. Job done see ya later nobody checks.
    I have just done mine I know this for fact
    PaulC and Moff69 like this.
  6. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    Tom,
    I makes sense really. Instant road tole reduction for no outlay. We changed Sally's to single in October last year and still had to get the Cert. Do you know when it changed and do you just fill out the single seat change form?
  7. SpittingCobra Husqvarna
    Tr650 Strada
    KLX400
    My point about not modifying seats is that dirt bikes and road legal trail bikes have long seats to provide some rider protection when descending a very steep hill. These are adventure bikes, designed for similar (although less extreme) off-road and shortening the seat could be argued to negate that design feature. I just compared the TR and "single-seater" KLX and both seats are 75cm.
    Moff69 likes this.
  8. FreddoFrog Husqvarna
    Scenic Rim, Queensland, Australia
    NC700SA, TTR250
    Just trawling through TMR web site, it appears that things changed on 1st July 2014.
    Reclassification of modifications to change a motorbike’s seating capacity
    From 1 July 2014 changes will commence that will mean that changes to a motorbike’s seating capacity will no longer need to be certified by an Approved Person and have a modification plate fitted.
    For Approved Examiners, this will mean that when inspecting a motorbike, the seating capacity that must be recorded on the inspection certificate will be determined by two (2) specifications:
    - Seat length: To be classed as a single seat vehicle, the upholstered part of the seat must be 500mm or less in length. If the bike has separate seat designed for use by a pillion this must be removed. If the seat is longer than 500mm or a separate pillion seat is fitted, the vehicle must be classed as a two seat vehicle; and
    - Pillion foot pegs: To be classed as a single seat vehicle, any foot pegs designed for use by a pillion passenger must be removed. If any pillion foot pegs are fitted, the vehicle must be classed as a two seat vehicle.
    For further information about determining motorbike seating capacity, refer to the [COLOR=rgb(0.000000%, 0.000000%, 100.000000%)]Vehicle Standards Notification [/COLOR]page on the Transport and Main Roads website.
    This is from http://www.tmr.qld.gov.au/~/media/busind/accreditations/approvedinspectionstation/aisinfosheet10.pdf
    Moff69 likes this.
  9. FreddoFrog Husqvarna
    NC700SA, TTR250
    I just went through the paperwork and I got my NC700 done 17th June under the old system, I could have save myself some dollars by waiting a couple of weeks!
  10. rajavw Husqvarna
    Kern County, California U.S.A.
    Terra
    V Strom
    Do any of you want to sell a Right REAR footpeg?
  11. Nick780 Husqvarna
    83 Suzuki GS400E
    Yours break too?
    rajavw likes this.
  12. rajavw Husqvarna
    Terra
    V Strom
    Yes SirEEE Bob!
    I reckoned that an Aussie bloke may want to part with a peg, especially after paying Rego as a Single Seater.
  13. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Hi Greg, where did you get that exhaust shield..?
  14. vodka Husqvarna
    South Australia
    TR650 Terra ABS
    R1200R , Yamy WR250R
    I would consider ,given that off road i spend so much time standing on the pegs to minimize the seat into a tankbag type thing and declare the bike a "no seat bike".
    What would that do to the costs? :banana:
