Steering stem bearing race removal
Discussion in 'Vintage/Left Kickers' started by Houredout401, Dec 9, 2016.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
  2. dingodog Husqvarna
    The Garden State, Au
    '73 CR125, '82 WR250,
    XC150
    If I could press it out I could treat any corrosion that's been working away for 35 years, especially between the dissimilar metals.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
    There should be room for a small bearing clamp remover? Then press or pull the bearing off using puller with threaded rods all the bearing clamps have two threaded holes.
  4. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    I used to grind the cup race off with a power file or a dremel but now just take it to a bike shop and ask them to press out the stem and fit a new bearing. Way easier and no risk of damage. My 6 tonne press won't budge the stem from the lower triple clamp.
    2premo likes this.
  5. Bigbill Husqvarna
    '83 250wr
    0 right now
    Press and heat. I call heat my 2,000 degree liquid wrench. From my years of heating things only half the diameter needs to be heated.
    2premo likes this.
  6. Bigbill Husqvarna
    '83 250wr
    0 right now
    My point is by heating the whole diameter we put too much heat that will transfer into the shaft. Heat half the diameter will expand half the diameter more and release the bearing.
