Step by Step air box and air filter modification
Discussion in 'TR650' started by drzcharlie, Mar 14, 2014.
  1. DerBrizon Husqvarna
    2005 Suzuki SV650S
    Your video (part 2) stops before it shows how you fit the 90 on to the throttle body. You mention using a razor to cut the rubber throttle body coupling to fit the 90, but it doesn't show it in any way. Can the rubber coupling be removed without removing the air box and the 90 clamped directly to the throttle body?
    Thanks!
    Edit: nevermind, I fond the other thread right here http://www.cafehusky.com/threads/how-to-change-the-tr650-air-filter.40519/
    there's images of the gromet/coupling removal. :) Starting on this soon.
    mag00 likes this.
  2. glitch_oz Husqvarna
    AUS
    Strada
  3. CRSAM Husqvarna
    Kent, Washington
    650 Terra
    53 Harley 165ST, CRF230
    I did the pod mod following the examples of several of the contributors before me. I did the hot knife cut per Big Dog and as with Glitch oz I removed the upper part of the rubber grommet so the air box could sit on it. I used an X-acto knife with their chisel accessory. It's very sharp and I was able to easily make a clean cut around the grommet flush with the air box base. I also cut 1 1/8 inch off one end of the 90 degree hose so the uni filter can sit lower the air box. In total it took about 2 and a half hours. Thank you to all who pioneered this fix.
  4. DerBrizon Husqvarna
    2005 Suzuki SV650S
    I just finished doing it tonight and ended up cutting some off both sides to get the filter to sit inside completely so the air box could come back together. I need to find a way to seal it now, though. What have others used? i thougt of just caulking it - it'd be easy enough to peel off and recaulk every time I need to open and clean it.
    Also, though I've never been off road with mine except once (and there was no dust) the throttle body was coated in soot.
  5. CRSAM Husqvarna
    Kent, Washington
    650 Terra
    Followed Big Dog's suggestion and used Gorilla tape. Duct tape is not as "sticky" but would probably work as well.
  6. craig hodges Husqvarna
    tr650
    Just read through the entire thread. I must say how glad the POD MOD has worked out for those who have choosing that path. Having this forum makes owning the bike that much better, so many fantastic ideas bounced around.
    They say necessity is the mother of invention. The engine failure due to poor inlet air filtration led me to the POD MOD idea. Getting to bounce ideas around with Charlie was great. Spending time working on the bike was fun too.
    For the record, both modified bikes are running great. I have found no trace of dust in the throttle bodies. Now....what's next. Njoytheride
    BTW, what does POD MOD stand for ????
  7. Terramoto Husqvarna
    TR650
    RM250
    After reading as much info on the different fixes for the air box problem I have decided to do the Pod Mod.
    My Terra has 4750 kilometres on the clock having had 2000 of them when I bought it. I have only just had a chance to take it off road last weekend so most of the work has been in clean air.
    The interior of the air box as expected was dusty and TB was dirty as well.
    I am soooo glad you guys found and sorted this problem. View attachment 43294
  8. V8Astro Husqvarna
    Central US / Missouri
    2014 Strada / 2008 SMR510
    Suzuki GS500, Yamaha TR125L
    Is anyone else having oil blown into the air box from the crankcase breather? I just did the Pod Mod and replaced the swollen crankcase breather hose at the same time. I'm now having oil blown out of the breather element
  9. Baddrapp Husqvarna
    Yucca Valley
    TR650
    Where did you mount the breather? I will check mine.
  10. V8Astro Husqvarna
    Behind the original air filter access door.
  11. Quirky Husqvarna
    Hunter Valley, Oz
    TR650
    R1200GS
    Yes, I got mine fixed up good now. Page 3 of this thread just in case you haven't already seen it.
  12. V8Astro Husqvarna
    I missed that part. Good idea! I'll be going back into the bike once I get my new air box lid (messed up the first one). I'll have to move the breather while i'm in there
  13. V8Astro Husqvarna
    I went back and did my POD MOD again. I wasn't happy with how I cut the air box lid the first time. I ordered a replacement from Halls. FYI the new lid had a KTM sticker on it....
    I also wanted to add a support so the bottom of the air box wouldn't sit on the fuel rail. I made a "seat" out of a 3" PVC pipe cap. I used a 2.25" hole saw in the drill press and a band saw.
  14. Quirky Husqvarna
    Hunter Valley, Oz
    TR650
    R1200GS
    That looks like a top idea.
  15. drzcharlie Husqvarna
    Great work.
  16. tweber Husqvarna
    Annual Tour de Go West
    Tr 650 terra
    Zippo
  17. V8Astro Husqvarna
    Dry fit. The "spacer" float around a little bit on the throttle body but it's enough to support the air box. After a nice evening ride I'm about to crack open an Imperial Stout and go have a look make sure the spacer isn't sagging or moving around too much.
    I will report in the morning :)
  18. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I like the 100,000 miles, that's 163,000klms
  19. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I
    I changed the screws holding the fuel injector, long enough to pass thru' the airbox, with neoprene roofing washers to support the weight
    I also used a 2mm thick neoprene rubber cover approx 300mm x 300mm cut-out for the fuel filler to tay over the airbox joint, this also had the effect of quietening the throb & reducing weather leakage into the airbox etc etc
  20. tokor Husqvarna
    Finland
    Husqvarna 701 Enduro
    I would like to do a pod mod change my bike but I was wondering dare I to do it. If I do it, so I lose the warranty from the engine, bike guarantee otherwise remain.
    Here in Finland we have two years warranty on motorcycles.
    How long do you have guarantee on motorcycles?
