strange clunk
Discussion in 'Vintage/Left Kickers' started by moto_surfer, May 19, 2017.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    I put the kick start lever on, wind up the spring to the correct location then drop on the pawl, let it hit the stop cam.
    Trust me we all learn the hard way in the beginning.
    My first 83 250wr rebuild I bored it put in a new piston and it didn't last long. What are crank seals? Leak down test? I learned right away. I installed new crank bearings, seals, leak down tested it. Rode it, parked it, next bike?
  2. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Bill, he said in an earlier post that he followed the Huskydoggg youtube vid on how to install the kicker components including winding the spring. Since I know little about this era Husky I'm curious, what should he of done different to avoid of all things a broke center case?
    Heres the vid he shared. https://www.youtube.com/watch?feature=player_detailpage&v=_Va1ZUZF6jk
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    did you grind away on this for quicker engagement? what condition were the idler bearings in? is the idler gear what pushed the case open?
  4. DaveM Husqvarna
    Adelaide, Australia
    2001 TE 570
    Motorised Bicycle
    These things are sent to test us, don't give up! It will be worth it in the end.:)
    moto_surfer likes this.
  5. moto_surfer Husqvarna
    Chinook, WA
    1981 430XC/ Silver Streak/TE300
  6. Crashaholic Husqvarna
    So when buying one of these bikes what would a person look for to be confident this doesn't happen after getting the bike home? Can a guy check for to little travel on the kick starter lever before it engages or does the cover have to come off to tell that its okay and not going to explode the center case after the purchase?
  7. justintendo klotz super techniplate junkie
    hmmm, looks like the kick idler gear suddenly stopped...when that happened the case got stressed and cracked.
    after you assembled, did the kicker make a rattle or knocking noise when the bike was running? almost seems like the kicker tried to engage with the engine running.
  8. justintendo klotz super techniplate junkie
    yeah, you will want to make sure the pawl is tucked in the whole way when the kicker is at rest..its a good idea to periodically replace the caged bearing on the kick shaft and the idler shaft for good maintenance. maintaining good kick habits greatly prolongs everything in the kick assembly, like feeling resistance then kicking thru...instead of just stabbing it. i think this is what tears the pawl up.
  9. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Kick back could have caused this.
    How is your ignition timed?
    Tony.
    moto_surfer, Crashaholic and DaveM like this.
  10. moto_surfer Husqvarna
    Chinook, WA
    no the kicker didn't rattle or knock, I made certain the pawl was not engaged and fully retracted when the kicker was in the rest position. Two gears on the idler were broke off when it stopped suddenly.
    Tony mentioned that timing could be the culprit and the kickback could have caused it. I'm not sure I'm qualified to respond on how it was timed. It started easy and ran good so I never checked it since Ive owned it.
    I really appreciate your input guys and I'm learning a lot about this bike. When I do find a set of case$ the real fun will begin because I've never split a case before so I'll be at your mercy
  11. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    did you find a set of cases??
  12. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    Check condition of the small gear on backside of clutch basket and post pic of it plse.
    86 400 XC likes this.
  13. moto_surfer Husqvarna
    Chinook, WA
    I have a couple of leads on cases but nothing confirmed yet. Will this set of 1983 500 CR cases work? http://www.ebay.com/itm/Lower-engin...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
  14. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    yup they will. 82 to 88.
  15. husqyhamm Husqvarna
    South Africa
  16. moto_surfer Husqvarna
    Chinook, WA
    I will check this out when I get home.
    Ok so I let me get this straight: Any 1981 to 1988 big bore lower cases will work without modification? I was told 250's of that era need some modifications to work? Please confirm
  17. 2premo Husqvarna
    Northern NV
    the cases are similar but the 250 has a smaller crank area that can be bored out but what hassle
    justintendo and moto_surfer like this.
  18. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    I have 1 mint L. side case (R side has a worn rear steel insert) from a 85/6 400 or a pair of mint 82 250 cases i can sell.
  19. 86 400 XC Husqvarna
    Calgary
    more Huskys
    All I found is 1 little pit in crank area, I will remove the studs and rear insert for you.
    The single shock cases have a larger hole in the insert for the swing arm pivot bolt.
    20170710_185639.jpg 20170710_185646.jpg 20170710_185716.jpg 20170710_185700.jpg
    justintendo likes this.
  20. moto_surfer Husqvarna
    Chinook, WA
