Stupid questions or not..?? Husky 650 Intermittent Stopping
Discussion in 'TR650' started by kiwiape, Apr 2, 2014.
  1. spiderman Husqvarna
    Decatur, IL
    07 KLR650 07 Bandit1250 85 Rokon
    I don't normally use any throttle during starts until it starts running really bad. I get to the point where it won't start after hitting the starter button 5 or 6 times and then I really have to throttle up a bit but that's only as a last resort. And this situation only occurs a couple thousand miles after a remoss. Also, this last time I tried the startup relearn procedure as you described and it didn't help. That's when I took it back to the dealer.
    I don't discount that I'm doing something to cause the change but I honestly don't know what it could be. I've tried not using my LED running lights and heated gear. The Wuka is the only thing I've added to the mix. Still have the canister and both exhausts. Haven't done the pod mod yet and don't have a cooling problem. At 10k miles I've not checked the valve clearance which could cause a hard starting situation, but since it works just fine after a moss I doubt if that's an issue. If this last moss update doesn't take care of the problem I'll be going with the PCV but i hate to spend that much $ to get the bike running the way it should out of the crate. The dealer has been great to work with and is frustrated with all this as I am.
  2. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Missing valve check could cause starting problems. Don´t touch the starter button too tender, let it turn a few times.
    Using the throttle while starting will cause problems because that writes an error to the map and changes idle position and speed!
    I would say that is definitly your problem.
  3. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    I have to interject here about the "don't use throttle" at start up.
    My bike has had intermittent cold start issues.
    It would turn over, just catch, then die. It does not just keep turning over.
    It can take numerous stabs at the button to get it to start and stay running.
    Out of frustration I broke down and tried pushing the button then immediately cracking the throttle just a bit, like I do on carb bikes that are stuborn starters.
    Bingo, the bike fired off and stayed running.
    No idle issues, no stalling.
    Now whenever it does not fire off on the first try, I crack the throttle and the bike starts up & runs just fine.
    Again no idle issues, no stalling and no other running issues.
    I know this goes against everything I have ever heard about EFI, particularly of the BMW 650's, but on mine it works just fine.
    PaulC likes this.
  4. hikewithmike Husqvarna
    Sammamish, WA
    AFAIK, I have had no issue doing this on cold morning as well. But then again, I know have check engine light that came on with source unknown.
  5. spiderman Husqvarna
    Decatur, IL
    No that is definitely NOT my problem. As I stated earlier, I have cracked the throttle on start up only after the bike has given me problems, hence the need to resort to that technique to get it to start.
  6. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Get a small allen wrench and give ye ole idle stop a 1/6th to 1/4 turn clockwise.
    I checked, and 1/6th did not change the tps resistance, but 1/4 did.
  7. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
    Hope your dealer isn't far away?...
    Sounds like one of your sensors isn't talking to the ECU... or a intermittent fault with a sensor.
    temp, elevation, humidity, timing, oxygen = mixture (willing to be corrected on this):)
    Hey, Just throwing it out there!
  8. spiderman Husqvarna
    Decatur, IL
    Thanks for the help guys. The dealer is only about 35 miles away and I don't mind making the trip. Hall's Motorcycles in Springfield has really gone out of their way to work on this and is currently trying to get help from Husky Central. I'll keep those ideas in mind if they don't come up with something. On the back burner like I said, is the PCV. I'll have more questions about that option later.
  9. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    I can only speak from my experience, once used the throttle when starting led to problems such as backfire to the air filter, stuttering and intermittend stopping. I was able to solve the problem by the reset i described. Every dealer told me that using the throttle while starting writes an error to the map an causes such problems. That is all I can say.
    I have no starting problems on my terra, not even when it is very cold.
    I think PaulC is right, starting issues and the other problems described allow the suspicion to faulty sensor. If so no update of the map can help.
    Good luck ;)
  10. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    You would think that a permanent or intermittently faulty sensor would write errors in the ECU which would be reported when it was plugged into MOSS.
    mag00 and snail_72 like this.
  11. megatiker75 Husqvarna
    Italia (Liguria)
    TR 650 Terra
    Kawasaki ZX6R 2001
    next Tuesday I will bring the bike to do the upgrade with moss. I'll tell you 'if I disappear from the written MAP II display at startup. And if it will change anything. I remind everyone that I once an update that I improve 'the problem of deadlock, but not completely resolved.
  12. megatiker75 Husqvarna
    Italia (Liguria)
    TR 650 Terra
    Kawasaki ZX6R 2001
    [IMG]Hello to all. Today I brought the TR650 by the dealer to do an update of the controller. Many of you had said that it had come out a new one and so I tried it. Unfortunately (at least here in Italy) the bike has the same update that I did last year. The writing on the dashboard MAPII I have left. and also the problem of unwanted off of the bike. I attach the screen of the software update. Has made me a mechanic. I'll try again some day so the bike but then surely I will link again my wonderful and miraculous booster plug.
    Nordland and PaulC like this.
  13. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    a glimmer of hope.....
    I am in contact with the Production Manager for Motorbikes at Magneti Marelli, Italy (the people who made the ECU's for our bike). He is asking his colleagues who worked on the Husky project for comment about our problem.
    Fingers and toes crossed everyone........:)
    Dutchgit, run-it, PaulC and 3 others like this.
  14. drzcharlie Husqvarna
    Outstanding kiwiape....wow, thanks for doing this.
  15. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    no problem, but we are not there yet
  16. spiderman Husqvarna
    Decatur, IL
    Got my bike back from the shop with the "latest update released to the dealerships" in the U.S. which is V 14. Still says map II on display. I haven't had a chance to put any miles on it yet and it will probably be near the end of the week. They also said they were able to talk to the factory tech about the problem and they're very interested, especially since I told them of my safety concerns. Even though the bike is well beyond warrantee they didn't charge me for this service. They're making every effort to work with me on this issue.
    PaulC likes this.
  17. drzcharlie Husqvarna
    Which dealership?
  18. spiderman Husqvarna
    Decatur, IL
    Hall's Motorcycles in Springfield Illinois. Great people there.
  19. megatiker75 Husqvarna
    Italia (Liguria)
    TR 650 Terra
    Kawasaki ZX6R 2001
    Have you tried the new map? And 'gone wrong? in my case, unfortunately, was still present and I have already reinstalled the booster plug.
  20. spiderman Husqvarna
    Decatur, IL
    I haven't had a chance to try it yet. Out of town right now and I hope to be back by the weekend. I'll let you know. Booster plug is ready...
