So I'm having the biggest problems getting a 2003 RM125 to idle.
It didn't run properly since I bought it secondhand almost two years ago, ran always rich.
So far it has had two rebuild done by me (two pistons, one cylinder, and a new crankshaft assembly, all gaskets new every time).
One problem we only recently discovered was that the flywheel-weight had a worn trigger? (block on the circumference). It basically was so worn that it didn't even have the correct size/shape so naturally it didn't ignite when it should (way to late I assume). Anyway fixed that with a new fww.
I expected a big improvement in running, and was hoping it would idle.
The noise is definitely better, but still won't idle.
So I adjusted the idle screw and checked the air screw, got it to idle when the idle screw was wound in as far as it could (bad I know).
Started swapping pilot jet's (from 37,5 to 30 and everything in between), didn't really make a difference and turning the air screw doesn't either (although once you turn it in farther then 1 turn it dies but that's only logical).
I tried the stock and fmf recommended jetting. Still no joy.
Checked the spark with a new spark-plug, looks good to me (ngk br9eix iridium).
Bike gets maintained properly and looks tidy.
Below are the jetting settings (150meter altitude, 20degrees Celsius) Mikuni TMX (the new version)
Pilot: 37,5 - 35 - 32,5 - 30
Mainjet: 440 (tried 450 and 460 too)
slide: 5.0
Needle: 6bgy28-77
Clip: 3 (tried 2 too)
Air screw: 1,5 (adjusted too)
Checked for air leaks, couldn't find one (all gaskets were renewed two times by me).
I'm kinda fed up with this bike, put a lot of money in it, and it still doesn't run properly.
What else can I try? I'm suspecting some kind of electrical problem (CDI?).
The strange thing is I closed the pet cock, and it began to idle increasingly faster (to a point were I had to shut it of). Then I realized when the bowl goes empty it starts to run leaner. so should I try a 27,5 pilot jet?
slide: 5.0
Needle: 6bgy28-77
