Suzuki RM125 won't idle
Discussion in 'Non-Husqvarna Motorcycles' started by Bart, Sep 3, 2014.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    What about your ignition timing?
  2. Bart Husqvarna
    The Netherlands
    2008 TC450, 2006 WR250
    2009 TM Racing EN300 and EN450
    Thought about that, the stator is aligned with the mark on the crankcase so should be good.
    However I'm not sure the crank is an OEM one, could be after-market. Shouldn't be a problem but I've heard stories were the fww key was slightly off.
    I'm going to try bigger pilot jets, just to try as I'm thinking it needs leaner ones. Have to try something right. Very confusing.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Check it with a dial indicator just to make sure with piston up by what is marked.
  4. Bart Husqvarna
    The Netherlands
    Problem is I don't know what the height must be. Very hard to get information of Suzuki, can't even find an owner's manual.
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Roll piston up to top dead center than kinda look at your mark on flywheel and magneto to see if you are kinda close.
  6. Bart Husqvarna
    The Netherlands
    Will do!
    I had an epiphany, when the pet cock was closed it began to idle and increasingly higher which led me to believe the float height is to high.
    I set the float to 7mm as the following picture on this page suggested, which is rather high, per Suzuki instruction it should be 8,7mm to 10mm.
    So I'm going to set it at 9mm and try AGAIN.
  7. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
  8. Bart Husqvarna
    The Netherlands
    Really hard to measure with a vernier caliper (parallax), I'm not sure it's set correctly. However noticed that the tap that touches the metering pin of the floats is a bit worn. So I had to bend it quite a bit further then the picture shows to get it near the 9mm.
    Anyway installed the 37,5 again, and got it to idle when the idle screw is turned in full (shouldn't be like that). I'm waiting for a 40 pilot jet to be delivered.
  9. Bart Husqvarna
    The Netherlands
    Problem has been found, low on compression.
    It suddenly got really bad, could rev it to the moon and but hardly did move (sand track).
    Pulled the cylinder and noticed there was a piece off ring missing (about 2mm), also the ring was worn as I could clearly see light between cylinder wall and ring.
    Anyway decided to send the cylinder in to get a new plating, new top end and hopefully that's the end of it.
  10. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    wow, amazing it still ran as good as it did. two strokes can be pretty tough
  11. Bart Husqvarna
    The Netherlands
    It ran yes, but didn't produce any power. I'm hoping once I get it replated in a week or so it does perform (it really should shouldn't it).
