125-200cc Switching from BR9EG to BR8ES??
Discussion in '2 Stroke' started by Yellowfin, Mar 4, 2015.
  1. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I have no idea how to check that, Im pretty handy except electrical issues
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    You would need a puller for the rotor, dw its unlikly thats the cause but it is possible.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I agree, 1 step hotter with the plug range shouldn't hurt anything, Iridium plugs are worth it, and the type of plug and heat range isn't causing the issue.
    If you've been racing you need to check compression and ring gap. I like some bean oil too and was using Maxima 927, bike ran and smelled great, but too much spooge while woods riding. Just switched to Kotz Techniplate (my old fav) and spooge is reduced to just a dribble. Both @ 40:1.
    There's a lot of confusion about rich/lean mixtures: more fuel=richer, so 40:1 is richer (and hotter) than 32:1.
    I would start with basic Husky troubleshooting:
    intake/reed block/carb boot air leaks;
    also make sure you have a good seal on the Lectron, mine has to be pried a little forward before tightening the clamps;
    crank seal? no water in oil;
    strong spark? I still don't trust the late model digital setup;
    check the plug cap and wire for damage and under the tank connections too.
    Lectron carb is a really simple device, it should just work. If not, there's some other issue. I've seen a couple of folks blaming the Lectron without confirming good compression, fresh rings, no air leaks, etc.
    I would put the Lectron back to stock settings, @ 51mm rod length, 1 turn out on the PJ, 1-1 1/2 out on the idle screw and see how the bike starts and runs and tune from there. Use fresh fuel, plug, filter, etc.
    How did the bike run before the Lectron?
    :confused:
    Yellowfin and justintendo like this.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i like to buy the gallons!!
    NCSteve likes this.
  5. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Yep, me too. Even makes weedeaters smell good.
