SWM-IT Husky parts cross over list.
Discussion in 'Husqvarna Cousins - Cagiva, etc' started by Original Dirt, May 4, 2016.
  1. BASHER DAVIS Husqvarna
    None
    Swm RS650r
    CHECK OUT MY SWM OWNERS CLUB PAGE ON FB...... YOUR NEED TO JOIN, IN THE FILES SECTION, I HAVE MANY SWM PARTS BREAKDOWNS AND USERS MANUALS LISTED, *** INCLUDING HUSQVARNA TX TXC SM TE 310 450 510 I HAVE LISTED THE HUSKY 630 MANUAL ALSO.
    You can cross reference the Swm manuals on my page with husky ones to determine if parts will fit, it takes the quess work of things.
    Also as a point of reference, The parts only fit if the ** PART NUMBERS ARE IDENTICAL**
    IF THE PART NUMBER HAS A PREFIX LETTER OR DIFFERENT NUMBER BECAUSE THE PART HAS BEEN MODIFIED OR UP DATED ITS NOT COMPATIBLE AND WONT FIT.
    Come join us on fb we have 650 members and it’s a busy fun page..... also members will often post compatible pattern parts and accessories that fit their Swm bikes
    I hope this helps
    Bonn likes this.
  2. Original Dirt Husqvarna
    East Coast USA
  3. Original Dirt Husqvarna
    East Coast USA
    That set up should work, no problem.
    Bonn likes this.
  4. David Hoffman Husqvarna
    Carrollton, Georgia
    TE610
    Ducati Multistrada 1200s
    What about using the Seat Concepts seat from the 510? Does it fit?
  5. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    Nope, the plastics and seat base are different between the TE510's, 2016-17 RS/SM and the 2019 SM/RS's are different again...
    David Hoffman likes this.
  6. MuskyHusky Husqvarna
    nc
    2012 cr144 1983 wr250
    maicos
    So is there anywhere I can actually purchase swm parts in the US or that ships to the US? I was wanting to convert my 2009 smr 510 to 2017 swm rs500 side panels, tank shrouds, radiator shrouds, decals and seat and I can find all the part numbers just can’t figure out where I can buy them
  7. Original Dirt Husqvarna
    East Coast USA
    https://www.motomandistributing.com/swm-dealers
  8. nickknack Husqvarna
    510 SMR
    Does anyone know if the rear wheel/hub off an SWM SM500R is compatible with an 09 510 SMR? I'm thinking if I buy the whole rear wheel assembly, with SWM sprocket, then use my existing axle/rear brake setup I should be able to make it work but I'm just guessing here. Any insight?
  9. Appalachian Husqvarna
    None
    SWM RS500R, XR650R,WR426
    The part numbers changed but i too want to know. I have a 2019 RS500 that I want a supermoto setup for. Warp 9 told me they have 0 interest in making wheels for SWM so I want to know if the husky is heels will fit the SWM.i can get the Alpina wheels from Italy but that’s close to 2 grand but they are tubeless spoked wheels
  10. Appalachian Husqvarna
    None
    Stupid autocorrect : “husky is heels” should be “husky’s wheels “
  11. SM26 Husqvarna
    Israel
    SMR 500
    sold my 701 to get SMR
    didn't saw anyone mentioning it so he is my short list:
    Oil filter:
    Aprilia RXV/SXV 450-550 2009-2015 P/N: 9150166
    Old Husqvarna P/N: 8000B0593
    HiFlo HF563 is a direct replacement
    Timing chain:
    MV Agusta uses the same timing chain
    P/N: 8B0035794
    96 links
    Case Saver:
    Moose racing makes a case saver for the Husqvarna 2005-2010 TC/TXC/TE 450-510
    P/N: 0950-0380
    Front Disc / Rotor:
    OEM is Galfer DF645CW-ALU.
    SWM P/N - F000P01803
    but Galfer isn't the only option:
    Braking - WK059L
    Moto Master - 113039
    EBC - MD6293D
    And maybe even Brembo 108.A642.16
    Starter relay:
    https://www.ebay.com/itm/401497520205
    please note that on this one the terminals are swapd!
    Gas Cap:
    The stock gas cap is 67 mm in diameter
    Acerbis (IMS) - Carbon pattern P/N: 0016833.090
    Acerbis (IMS) - Black plastic P/N: 322100-BLK
    Please let me know if you find out about anything else.
    shrubitup likes this.
  12. Sjiefke Husqvarna
    The Netherlands
    Husqvarna 510 SMR '10
    Kawasaki ZX6R '07
    Oil filter / Strainer 8A007471
    (Nearly) identical between SWM and IT Husqy. Personally tried and tested...
    Bottom (kinked) is original Husqy and the top one is a new SWM one. Only the second ring of the machined part in the front has a smaller width. Total length is the same.
    Price Husqy $50,-
    Price SWM $15,-
    rancher1 likes this.
  13. ex-xt Husqvarna
    SW of France
    a clone mixed italian/swedish
    SWM 300 , RE himalayan 410
    I am ready to buy a new 300 RS but , as i am not talle enough, will need a koubalink help !
    does someone knows the part number of the genuine link ? the koubalink guys ask for it
    thanks.
  14. Sjiefke Husqvarna
    The Netherlands
    Kawasaki ZX6R '07
    In this link you can find the SWM part numbers, assuming your bike is a MY19;
    https://evolutionbike.it/swmstore/oem-parts/rs-300r-rs-500r.html
    The linkage number is 8000B0236
    This part number is identical to the following Husqy bikes. Whether the parts are 100% identical I'm not sure, but it is likely;
    LINKAGE SUSPENSION ( SMR 450R-530R ) ( 2009 )
    LINKAGE SUSPENSION ( TC 250 ) ( 2009 )
    LINKAGE SUSPENSION ( 250-310-450-510 ) ( 2009 )
    LINKAGE SUSPENSION ( WR-CR 125 ) ( 2009 )
    LINKAGE SUSPENSION ( WR-CR 125 ) ( 2014 )
    LINKAGE SUSPENSION ( TE-TXC-TC 250-310 ) ( 2014 )
    LINKAGE SUSPENSION ( WR-CR 125 ) ( 2013 )
    LINKAGE SUSPENSION ( TE-TXC-TC 250-310 ) ( 2013 )
    LINKAGE SUSPENSION ( 250-450-510 ) ( 2008 )
    LINKAGE SUSPENSION ( SMR 450R ) ( 2008 )
    LINKAGE SUSPENSION ( WR-CR 125 (CR 150 USA) ) ( 2011 )
    LINKAGE SUSPENSION ( TC-TE-TXC 250-310 ) ( 2011 )
    LINKAGE SUSPENSION ( 310-450-510 ) ( 2010 )
    LINKAGE SUSPENSION ( TE-TC-TXC 250 ) ( 2010 )
    LINKAGE SUSPENSION ( WR-CR 125 ) ( 2010 )
    LINKAGE SUSPENSION ( WR-CR 125 ) ( 2012 )
    LINKAGE SUSPENSION ( TE-TC-TXC 250-310 ) ( 2012 )
    https://shop.italhusky.com/en/search?search=8000B0236
    ex-xt likes this.
  15. ex-xt Husqvarna
    SW of France
    great answer mate , faster than on adv rider :applause:.
    gonna order it
  16. huskyfrk Husqvarna
    los alamitos Ca
    you might check w dubi ? correct spelling ? they are in SoCal, they are ex white bros employees who are building wheels. might give them a call...
  17. roamine Husqvarna
    Do you know if after market exhausts from Superdual fit on TE630? FMF and Arrow for the TE are discontinued for a long time and very hard to find a used one in Europe !
    Thanks
