Tard Vision Quest... (pic heavy)
Discussion in '610/630' started by Virginian, Sep 23, 2012.
  1. duanew Husqvarna
    2006 TE610
    WR250R XT225
    I read somewhere to take and glue that section down with glue before you stretch the rest of the cover in place. Hold it with a couple large washers and a clamp while the glue dries. The original poster suggested Gorillia glue but I might use something else.
    Virginian likes this.
  2. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    '12 Moto Guzzi Griso SE Tenni
    Added a 610 Case Saver from 7602racing.com
    Next up is to install new handgrips and Symtec heating elements. Freak'n brilliant of me to install these as winter comes to close here in the east....
  3. 1lunger Husqvarna
    Bloomfield CT
    Bling bling!
  4. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    I can't imagine where I got this idea from? hehe
  5. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    OK, in my never ending tard quest to bore you poor folks with my build and post about items that almost all of you have done; here's the next segment!
    Today was an expensive day. First off I ordered two new tires/tyres for the SM. I labored over every thread in this forum on rubber and pm'ed several members who were kind enough to share their thoughts. Many thanks goes out to the members of this forum. Words can't descibe the help I get from all of you. :cheers: What I wound up going with were Michelin Pilots. Bang for the buck I hope to get more than 900 miles out of the stock tire that was trashed.
    I called around and the only Husky shop in VA (that I know of?) is Motorcycle Factory Inc. in Woodbridge, VA. Believe it or not they had the best price on these tires within $10 of internet orders. So I ordered them and set the appointment to have them installed. $63 per rim to in stall... yikes... :eek: Set an appointment with service for today.
    I get up this morning... perfect... So much for riding down there and getting the install. I just didn't feel good about trying to ride home with new tires being so slick and snow and ice.
    I load up the trailer and off I go. 1.5 hours later I'm there and unload and do the waiting game. A couple hours later she done and I'm good to go. So I have a trailer and aluminum ramp that's fairly low to the ground. As I'm loading the bike up, the front tire with brake holding isn't enough to hold and the bike starts sliding backwards in the slick icy conditions. I lose my footing and down we go in a pile. A complete yardsale... :o I bounce up as any male with any pride left to see if anyone saw this mess, sure enough I had an audience. Someone came over and helped me load it and I get the hell out of there feeling like a complete horses arse. :doh: No damage to the bike as I managed to have it fall on me. Just my pride...
    New Pilots installed ready to be scrubbed in.
  6. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    Next up I installed Fastway F6 pegs. I bounced between the pivot pegs and these for a month. In the end the F6's won out for being rigid. The install would require some slight modifications to make them work. I'll post a little on that as I go. The instruction were mysteriously missing in my package so I looked on the net and found some to download.
    You have the option of setting the pegs in normal height or low position. I'm 6' 4" so low for me. This is accomplished by placing the metal bushing on the top or bottom depending on how you want it set up in the peg shaft hole. The bushing is a tapered fit and has to be compressed in. They provide a tool to hammer it in. I chose to just pop it in the vise and squeeze her together.
    After I removed the the stock pegs I test fitted them to see if they were level/or not when installed. As luck would have it, they were level on the 610 without any shimming required! They provide you ample shims if you need them. I should note that I had to remove the rear brake lever to get the stock peg off and install the new one.
    I had to grind the bracket on the bike a bit to get the peg to fold up properly. No big deal; about 5 minutes with a grinder and a couple of swipes with a fine file, good to go. I touched up the bare metal with some heat resistant rustoleum paint and let it cure.
    I fit the spring on, installed the peg and started to install the cleats. I would suggest using blue Locktite on these so if you don't like them, you can easily remove them and replace with something else. Time will tell if these cleats will eat up my Sidi's.
    Right peg installed.
    Left one required no alteration and was installed in under 5 minutes.
    As always, thanks for reading.
    Eric
  7. 1lunger Husqvarna
    Bloomfield CT
    Your feet will thank you!
  8. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    This weeks installment is a set of hand warmers and HDB upper and lower with mounts for a Ram ball for my GPS, toggle switch for the hand warmers and a Powerlet socket.
    Lowers installed. Model specific for Huskies!
    Checking the fitment of the upper and rearranging all the cables.
    Installed the heating elements on the handlebars.
    HDB even includes the tap for the bar ends. I have to say this was awful to the threads in the stock bars. After drilling out the ends in steps I started tapping... Good gawd, I needed a man sized come along wrench.
  9. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    I opted for the integrated LED turn signals built into the handguards and the mirrors that fold up into the handguards. I removed the stock turn signals and soldered on connectors on the new LEDs. Truly a plug & play. Awesome trick stuff!
    I went to wire up the heated hand grips and install the toggle switch and the dang thing wouldn't fit. It appears that they are sending switched a different diameter so I had to hand file and Dremel the hole a little larger to accommodate.
    Handguards installed with the mirrors.
    Here's a pic of the finished product without the Powlet socket installed. I'm still waiting on parts for that. It houses my Zumo 550 perfect and the heated hand grips are the shizzle! Best $37 I ever spent and get the job done nicely.
    Paul is a great guy at HDB and worked to meet my needs. He didn't just try to sell me something off the shelf when I had a specific need. Delivery time to from when I ordered to my doorstep was 3 days. That included fabrication of a custom bracket and anodizing.
    Thanks for reading my build,
    Eric
    DYNOBOB and Muddy Waters like this.
  10. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    Minor setback, my stock battery gave up the ghost at almost 5 years old. Unibat from unibatitalia.com no complaints from the service this battery performed.
    A member of this forum I've been confiding in on this journey turned me on to Moty batteries at motydesign.com and i spent some time with Brian Harris on the phone discussing the upkeep of this type of next gen battery. Super nice guy and I had a couple of take-aways from this conversation. The original Moty's were very small packs that were encased in shrink wrap. You had to pack foam around the battery to secure it in the stock cavity. He since has created a feux battery box to mimic the stock size for a slip install. Indeed it did fit as the stock battery would except being 1 or 2 shorter (which was fine with me). The stock rubber strap used to secure the battery did not have enough resistance so I packed an 1" of foam in the bottom, problem solved. I also though the foam provided some shock/cushion for the battery itself.
    Of course I hooked the polarity up wrong because the posts were opposite what the stock batteries were. Popped a fuse... Put that on my list of things I wish I had never done. lol
  11. EricV Husqvarna
  12. Virginian Husqvarna
    Spotsylvania, VA
    '09 SM610
    Eric,
    Thanks for the reply. I'm about done with farting around with it till this fall. I'm going to ride the wheels off of it this spring, summer and fall. I just wanted to get it to 100% before I ventured out really far from home on it. I set this up for sport touring and I'm working on a tank bag solution from what I have kicking around in the garage. I'll post that up when I get done. I have some other ideas for this bike but it will have to wait till later. Time to ride!
    Eric
