TE 250/310 xlite starter issues...
Discussion in '4 Stroke' started by smokinrider, Apr 18, 2012.
  1. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Such a shame this keeps going on, but I imagine it will never be fixed until they redesign the starting system.
    Before you replace the starter, you might check the starter relay. Mine went bad on my 2010 and would just click. It appeared to be good when subjected to a tester, but was in fact bad. Try the old touching the jumper cable directly to the starter. You only have to touch it not actually clip it on...if it turns over then i'd look at that starter relay. If you don't like sparks, then make a friend do it. :)
    6 hours isn't much, but who knows why these things go bad. I had one suddenly go out on my old KTM too.
  2. Connor Husqvarna
    Maryland
    '12 TXC310
    Please explain this. You mean unhook one of the leads on the battery and hook it directly to the starter? than if is starts that way than it is the relay.
  3. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    No, use a battery charger like a battery tender. Ground the negative and then briefly touch the positive to the terminal on the starter. It should spin if it is good. That at least eliminates the starter motor being faulty.
  4. Connor Husqvarna
    Maryland
    '12 TXC310
    We have tried that already. I must have misunderstood your post. sorry.
  5. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Today in Ballinger Canyon on some tight sandy steep singletrack stalled once with the fan running. Starter worked for a bit but would not start. Even kickstarting didn't work. Then tried the starter button and just clicked. I was in a precarious spot and didn't want to tip over so backed her down to a spot I could get the bike turned around and got it bump started. A few miles later had the same issue. Bump start. Said to myself it's too damn hot and that's it for todays ride. Hope Husky has a solution. My warranty is up May 18th ;-/
    Update... Dropped the bike off and it is on the list for starter recall so a week for the parts to come in.
  6. street2dirt Husqvarna
    World's Most Famous Beach
    12 TXC310, WR300, 85 125WR, 82 175XC
    BMW G650X
    Is there a way to know if you're starter has updated parts? No trouble with mine yet but...... And is it a recall or warranty?
  7. Indorider Husqvarna
    Bojonegoro, East Java Indonesia
    2010 TE 250
    Yamaha TZM, Suzuki RGR (2 smokers)
    I haven't replaced anything on my '10 TE 250 but you described exactly what happened to me two days ago and at the gas station this morning. First time I hit the button just turned a bit like a low batt issue, second time fired right up. Happened when she was hot and this morning after only five minutes of riding. I checked the battery after the first time it happened and all was well. I just checked the valves around 6 hrs (ride time) ago and they were perfectly in spec. I'm off to the mountains in Central Java in two days and just hope it was a fluke. There are some damn steep climbs I don't want to be trying to kickstart on.
  8. gergte310 Husqvarna
    LAKE MACQUARIE NSW AUSTRALIA
    TE 250 2st, TC 250 2st,TE 250R 4st
    HONDA CRF 150R, CRF 110,Z50,APRILLIA
    If your bike has the same issue and you keep hitting the button you will damage the battery and the starter motor - the problemm seems to be the starter worm gears and the starter clutch bearing replace all three parts i replaced two batteries and one starter motor before realisign the real cause - the jamming problem will over load the starter motor and battery so be carefull.
  9. gergte310 Husqvarna
    i cant beleive the 13 model has an issue but if so make sure they replace three parts the worm set and most important the clutch bearing
  10. SoCalHuskyRider Husqvarna
    2013 TE310R
    Husaberg FE 570, KTM 300 EXC
    According to my dealer some of the 2013 models received the starter upgrades while others did not (tracked by VIN number). Unfortunately mine had to make the trip back to the dealer for the upgrade. They replaced the worm gear and the flywheel gear under warranty.
  11. Ed Ventura Husqvarna
    CT
    2013 TXC310
    GG 300
    My 2013 txc will not start with starter. 6 hours. I have not talked to my dealer. Piece of S%%% starter system for sure. I bought the bike 1 week before the buyout was announced. It then sat in the basement for 6 weeks waiting for the snow to clear. Wish I waited to spring to buy a new bike.
    If I find that it starts well with the kick starter maybe I pull the whole starter system off. I have a rekluse in it.
    I have not had time to mess with it, just riding and loving my GG300
    ED
  12. R_Little Husqvarna
    NJ
    Two issues at work here:
    1. The design of the starter system is marginal to begin with. The old starter drive was splined to the crank in the 2009 and earlier bikes...very robust. The x-light has the starter sprag behind "a run of the mill 2 stroke type flywheel"...barely adequate. If the sprag does not lock up or the gears wear out, then the flywheel key shears causing advanced IGN timing.
    2. The starter is made in China and agian is barely large enough to start the bike when it is new.
    My 2010 TE250 is working fine after replacing everything and lapping and loctiting the flywheel.
    I am sorry to see the same problems into 2013 but given the design there is not much they can do. I do remember hearing that the crank and flywheel were upsized in 2013....I would have hoped the problems would be gone by now.
  13. gergte310 Husqvarna
    Still waiting to hear from the dealer this is interfering with my ride calendar this season so i am not impressed.
  14. Ed Ventura Husqvarna
    CT
    2013 TXC310
    GG 300
    I am also not super impressed. As expected I need to do the suspension before I pass judgement on the bike, but I am learry of putting another 700 bucks into it that I will not get back. An electric start bike that wont start with a resale 50% of what it was 6 weeks ago new. I am no stranger to resale issuies with a garage full of GASGAS bikes but geez, My wife might really kill me this time,
    Anyone have input if this is an easy kickstart only bike?
    Ed
  15. gergte310 Husqvarna
    Having quite a high seat as well as the kick start lever being in a high positioni t is quite awkward to kick start especially on the trail - lean against a tree look for level ground - awkward
    R_Little likes this.
  16. Ed Ventura Husqvarna
    CT
    2013 TXC310
    GG 300
    Not worried about the awkwardness of the kickstarter, I can just about flat foot the bike, I just need more time on the bike to see if it starts well hot or it can sometimes resembles starting a carbed 4stroke hot.
    Ed
  17. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    I spent about 3/4 of last season kick starting mine because it wouldn't electric start. Usually a first-kick bike when warm and the valves are in spec. I do one slow push through then bring it back to TDC and make a swift kick. Of course, mines a 2010. I'm short, so i understand the awkward kicking, but I have my seat cut and usually try to find something to put my left foot on (not always an option! haha).
  18. R_Little Husqvarna
    NJ
    Mine always started easy on the kick but the kickstart is hi and difficult as was noted above.
    I guess you could just remove the starter and grears and make it a kick only bike.
    Tthe TC250 starter hole plug will fit right in.
  19. gergte310 Husqvarna
    According to the mechanic the problem with the bike this time is too much valve clearance one of the exhaust valves actuates the auto decompressor. (supposedlly not the starter gears or sprag clutch) Valve clearances normally decrease so this seems a bit strange to me the only explaination from the mechanic is carbon build up possibly from running too rich this may of beeen caused by the 4hole injector which i replaced recently with the 12 hole injector and race ecu. Picking the bike up this morning fingers crossed.
  20. Connor Husqvarna
    Maryland
    '12 TXC310
    Let us know how it works out for you =)
