TE 250/310 xlite starter issues...
Discussion in '4 Stroke' started by smokinrider, Apr 18, 2012.
  1. RailwayRog Husqvarna
    Changed the ring gear and it started fine a number of times in the garage but the real test will be this weekend when I'll be out riding for a full day (Thrill & Chill Turkey Run).
    I'll update you after the ride.
  2. RailwayRog Husqvarna
    Alright update, went riding today in the 90 degree heat in some single track. About 3 miles into the ride the engine died and would not start for at least 5-10 minutes, this problem kept repeating itself until bailed out of the single track and headed back to the truck on some open road. On the fast open road it does not die (maybe it would make a nice street bike). My only guess is the heat from the engine is causing a problem with the fuel injection and or fuel pump, and the pump will prime every time the switch is turn on and off so the pump is not experiencing a total failure.
    I'm back to square one with the E start, it worked great in the garage when I first replace the ring gear but after heating up the engine on the trail it's back to hardly turning over, at least not enough to start the engine.
    So now I have to major issues, nice.
    Again all the riders on the Turkey Run today got to see how good the Husky brand is as they passed me or stopped to offer help, I was dead last by the time I bailed out of the woods (the sweepers swept me out of the woods).
    I never felt so frustrated about a piece of equipment. I tempted to write a letter to Husky USA (at least to vent my frustration) a matter of fact I'm going to start drafting one after I finish this post. All I got is a Corona, CA address, does anyone know if this is where I should direct my letter to?
  3. R_Little Husqvarna
    NJ
    If it makes you feel any better, after over a year of changing starters and gears and adjusting valves and relapping flywheels my e-start has been working fine!
    I really do need to replace the 4 pt injector with the new 12 pt and then it should run fine all over.
  4. RailwayRog Husqvarna
    Was there anyone thing that you suspected could have been the problem?
    My next part replacement part i guess I would be to replace the starter motor and I don't think there is any after market manufactures.
    When you relap are you referring to the ring and pinion gear?
    On the auto de-compression side what did you set the valve at?
  5. Tessier Husqvarna
    New Hampshire
    2011 TE310
    KTM 990 Adventure
    Well stick with it there are lots of us that are reading this and following your progress.
  6. RailwayRog Husqvarna
    I'm firing off a letter to them right now, i don't expect to get any satisfaction from Husky but at least i get a little of my frustration out.
  7. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Post up the address. I'll write one too. Maybe making our voice heard will help. It seems that one of Husqvarna's biggest problems is an utter lack of communication.
    The only thing that ever made my e-start work was changing out the starter, unfortunately. I did that last fall and it has been e-starting ever since. Since replacing that starter, I have been religous about checking my valves and I also will bust out the kick start lever if it even shows a tiny hesitation in starting. I don't want to burn out another motor.
    This company suggested to me that I send in my starter and they could see what they could come up with on repair parts. At the time, I was in the middle of race season and didn't have the luxury of being without a starter for an unknown length of time.
    http://www.stockers.com/index.php
  8. R_Little Husqvarna
    NJ
    The valves and the flywheel were the biggest issues I think.
    That particular exhaust valve is hard to measure correctly...it seems to change with every crank rotation.
    When I adjusted the valves the 1st time at about 50 miles it read .005 to I shimmed it 2 sizes and it should have been .009 but it measured .010 when I rechecked it. A year or so later it measured .011 so now I shimed it to .007 and it seems to be fine.
    The sheared flywheel key was a huge issue. It advances the IGN timing which causes the spark to early which I guess keeps the piston from reaching TDC at kickover.
    The ring gear may have helped too.
    In my case at least the e-start if finally working fine!
  9. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Just throwing this out there, for consideration by anyone having problems with their bike overcoming the compression stroke:
    When my 450 started having problems getting past the compression stroke, I tried a new spring in the ADC, and tore apart the starter. Nothing really helped. What I do now, is hold the manual compression release in as I hit the starter button, then release after 1-2 engine turns. With kinetic motion in place, the starter can then overcome the compression stroke and start. I've been doing this for about 3000 miles/6 months now with no adverse effects.
    ray_ray likes this.
  10. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    That would be awesome except for two big bummers:
    They don't sell the spring for the X-lite ADC as a replacement part by itself.
    The X-Lites don't have a compression release lever.
  11. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Dang, bummer. I've looked for the post with the pics of the x-lite ADC, it might have been your pics Phoenix, but I cant find them, anyone know where those big, clear pics are?
  12. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    Here ya go.
    http://www.cafehusky.com/threads/exhaust-cam-spring.17392/
    That stupid little spring made a huge difference. With the straight spring, using the kick starter was like kicking against a wall. You would swear the motor was locked up. After the new cam was installed, I could kick it 1-2 kicks. Unfortunately, the starter was already fried, so I ended up replacing that too.
  13. RailwayRog Husqvarna
    This is who I addressed the letter to. I called my parts supplier (ToyTec) today and he said for the 2012 models they have had no problems so far, so apparently they corrected those two major issues.
    Kris Odwarka
    Husqvarna Motorcycles
    371 Corporate Terrace Circle
    Suite 102
    Corona, CA 92879
  14. Tessier Husqvarna
    New Hampshire
    2011 TE310
    KTM 990 Adventure
    Anyone got an email address for him? That might be easier for those of us with an issue.
  15. RailwayRog Husqvarna
    This is a pretty important issue and email I believe does not have the same effect as a letter will, at least that's what I have been told. Will find out from my letter.
  16. ray_ray Mini-Sponsor
    The Philippines
    Heart wrenching story ....Its like your faith is being tested to a new height.
  17. MikeB Husqvarna
    RailwayRog: Let me see if I've got this right:
    - you started having problems with the bike not e-starting but would kick start easily.
    - you applied LOTS of amps to the starter but it still would only turn the engine over if the plug was removed.
    - the flywheel key and the decompressor have been inspected and are working.
    - you changed the ring gear and it worked fine in the garage.
    - on the trail the engine stalled when it got hot and would not re-start with e-start or kicker until it cooled down.
    - when it dies on the trail the fuel pump does prime when ignition is turned off and then on.
    I'm not a mechanic but: if you applied a LOT of amps to the starter it may be fried (or semi-fried which causes a heat related failure). If the bike dies when it warms up there's something else wrong.
    - when the bike died on the trail could you kick start it or was the engine "locked up"?
    - how many volts AT the starter when it's acting up?
  18. R_Little Husqvarna
    NJ
    I dunno..you can't apply any more AMPs to the starter than it will draw..can you?
    Coffee likes this.
  19. joedirt Husqvarna
    PA
    wr250
    My 2010 txc250/310 sometimes starts with the e-start hot or cold. The e-start just has a hard time getting the engine past tdc. I can kick start it all day long with no problems but there is a reason I bought an e-start bike. Are the starters known to go bad on the xlites engines?
  20. RailwayRog Husqvarna
    Let see if i can clarify my problems with the bike, sometimes it hard for me to make my post clear so bear with me.
    Before I changed the ring gear it wouldn't crank at all so I had tried starting it with two motorcycle batteries in parallel to have the extra amps available for cranking (like jump starting your car, does that make sense?), that's what I meant by a lot of amps. After I changed the ring gear it started multiple times in the garage with no problem using only the one battery on the bike. It wasn't until this weekends ride when the engine got hot it barely would crank again. I've been told that if I decrease my (ADC side) exhaust valve gap from .009 (presently) to .006 this will allow more compression out of the cylinder during starting. If this doesn't work I buy a starter motor for 200+ dollars.
    Now as far the engine dying out on the trail it only happened a few times in the past, I'd wait a minute and it started up and ran fine the rest of the day but those times I'm referring to the temperatures where much cooler than what I was dealing with on Sunday.
    So on Sunday what was happening I'd go for a few minutes in 2nd gear single track and it would die like as if you hit the kill switch, wait 10 minutes kick start it and go another few minutes, over and over until the sweepers got me out to some open road headed back to my truck. Funny thing was on the open road it ran fine even with the throttle wide open, my only guesstimate is the wind passing over the engine and gas tank kept things cooler. So it looks like I will be replacing the fuel pump. What else could it be?
    Hope that clears my post up and thanx for putting up with me, I'll get the bike straighten out some day!
