TE 511 Chain Slack?
Discussion in '4 Stroke' started by Cosmokenney, Dec 14, 2013.
  1. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    I think I'm going to try the Cycra CRMs. They mount closer to the bar mount. Pricey, though.
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I use those, like them.
    Whittaker likes this.
  3. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    I found the Cycra full racer pack on Amazon for $90 something. It came today so I mounted it up. The pack includes everything needed to mount them. I did have to uninstall my ignition switch and cut off the factory switch mount. But the switch came with an alternative mount which actually puts the switch in a better position. The Cycra is a very nice product and at that price was probably cheaper than the cycle gear stuff overall. I also got my Trail Tech woods bend bars today. Very comfortable. tmp_20131224_192653-198466248.jpg
    danny318 likes this.
  4. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Trying to check out at ziptyracing.com. Used the Cafe Husky coupon code and the system wants to charge $14.30 for shipping.
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Try again.
  6. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Done. Thank you!
  7. Lon Husqvarna
    Brisbane Australia
    '13 TE511
    If I had a dollar for every time some "Numpty" says to me "Hey, your chain is to tight", id be able to buy me a new bike by now. :banghead:
    Cosmokenney likes this.
  8. NC Rick Husqvarna
    Asheville, NC
    2011 TE 449
    Dr 650, KLX, Ducati track bikes
    I'm going to guess that the chain should be set to have a 5mm play "gap" and not the 0.04" which is also specified in the attachment. By my admittedly poor math .040" translates closer to 1mm.
  9. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    I've seen bigger errors in the manual- my son's 2012 511 calls for a 2 or 3 inch valve clearance.
    found it. how about a 15" clearance. Not only off by a couple of orders of magnitude, but the conversion is wrong- add to that, the goofy euro comma is used intermittently for our decimal point.
  10. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Yea, 5mm is good. Looks tight. But it works fine.
  11. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    Run at least 20mm slack.
    5mm is hard for some people to gauge and they often end up too tight.
    There's NO harm in running the chain a little loose (other than a bit of chain rattle at low rpm), however, we've seen quite a few damaged bikes with worn out countershaft splines from over tightening on our FB page.
    Run it a little loose, keep it lubed, ride happy.
    tonskiguy, Big Timmy and Trenchcoat85 like this.
