terra 650 eratic/high idle
Discussion in 'TR650' started by MotoXotica, Sep 28, 2017.
  1. CarstenB Husqvarna
    NL
    F650GS Dakar
    that's weird. The Terra doesn't have a pressure sensor. Could it be the O2 sensor in the exhaust header?
  2. CarstenB Husqvarna
    NL
    F650GS Dakar
    duh, of course it has an atmospheric pressure sensor. It's built into the ECU - #9 on page 2
    http://www.f650gs.crossroadz.com.au/Repairs/BMS/BMSE-Info.pdf
    Here's what Wayne thinks
    "The fault Kodiakgpop has is quite interesting and does suggest a value received by the BMS-E is ramping up or down resulting in the idle ramping up. It would suggest water ingress into a component or damage resulting from ingress at a previous time"
    Do you have the other fault codes too?
  3. Kodiakgpop Husqvarna
    TR650
    KLR650, XR400, Aprilia Mojito, GS500
    There were other codes, 7 in total were listed by the shop using the gs911 tool.
    Ambient Pressure Sensor - Voltage too high
    System voltage Malfunction
    Oxygensensor heating circuit - short to ground or open circuit
    Oxygen sensor circuit malfunction
    Idle actuator motor malfunction
    Intake are temp sensor - voltage too high
    CAN BUS Off
    They cleared all the codes except the Ambient Pressure Sensor and System Voltage Malfunction. The Maintenance light is on as well.
  4. CarstenB Husqvarna
    NL
    F650GS Dakar
    wow, might be all possible error messages right there... Can't help much there but a short somewhere due to water ingress seems indeed plausible or a chafed wire maybe?
    What is the maintenance light? The flashing wrench? That's just a reminder that a service is due.
  5. Mark_H Husqvarna
    Lapu Lapu Cebu Philippines
    The Pressure Sensor is not in the Airbox, it is in the base of the ECU.
    The error is consistent with irregular Voltage pointing to Regulator Issues.
    duibhceK likes this.
  6. duibhceK Husqvarna
    Chapel of the Well, Belgium
    TRX850; WR450F; XT660Z Tenere
    I'm with Mark on this one.
    nev.. likes this.
  7. LainattheWired Husqvarna
    Check your fuse for the o2 sensor heater, then check and make sure sensors heater is working. Had exact same problem, heating circuit was causing high idle of varying degrees.
    7.5 amp under the seat
