125-200cc Test rips... Andy's '09 WR125 (CR Hybrid)
Discussion in '2 Stroke' started by pahusky, Mar 7, 2011.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx a million! Looks like you marked the seal as well. Is that where your key way is landing?
  2. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    Actually this pic is from wally's bike in another post ''cr's only - wr's beware''. Truthfully, I never noticed the seal mark...not sure what it's about.
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Got my Cr ignition tonight. On the stator plate it had perfect round washer marks from when it was bolted on in the past. The timing mark lands perfect on the edge of the casting. In other words the blue mark looks like it is about 1mm further in from where this one was set. Won't know 100% until the tool arrives. I also picked up a dial indicator and made a holder for it, drilling out an old spark plug and installed some set screws. It works good. I, as well, have to lengthen my wires and make a bracket this weekend for the CDI box. I have to order a 37.5/ 35 pilot just in case and also some other parts but will zero in on your settings.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Guess I'll have to get with my graphics gal and have her make up some CW125R and CW150R decals.
  5. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    How about "Frankenhusky"? [IMG]
    dartyppyt likes this.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Okay, Half Cr Half WR!
  7. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    If the weekend is decent, I'll set the timing a little more towards the lower edge. (Rotate counterclockwise) Closer to TDC.
    Spec says stock timing is 4 degrees btdc. I think the consensus was that the 'blue mark' is most likely retarded 1 degree, or set around 5 degrees btdc.
    I'll do some comparison videos, check the plug and see what Andy's take is...
    Krieg, nice piece of equipment...can't believe it has an identiy crisis right out of the crate...weird!
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    If his bogs out of the crate he'll need the WR igntion [IMG]
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Hey, got the tool last night and raced back to the shop to dial it in. Looks like I am 180 degrees from where you guys set your mark. Good thing I had my bifocals on, that pointer sticking out can pokemon your eye out! It lined up perfect with my bifocal line! My vision is not what it once was, the older I'm getting. Thru my glasses, I saw 3 pointers, so I used the middle one. Maybe, I had it on backwards!:lol:
    Just teasing! Actually, my mark is right on the money like the photo! All I need is a CR crank nut,some pilots, some odds and ends, and don't forget some lightning and Frankenhusky is alive! :eek:
    Thanx!
    Darin
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Okay, got my Cr ignition on and dialed in. Pahusky, I used your carb settings exactly but my needle ran the best 4th slot down. You were on the money! The bike rips, no bog, no hick ups, revs up quick. So, I thought, wonder what would happen if I tried the PWK 38 AS striker with the Cr Ignition? I went back thru some jetting posts and MattR's seemed reasonable.. I went off of his exactly and seems to have a little more bottom end and rips up top as well! I think it works great with the CR ignition.
    Here are the settings:
    09 Wr125 with 02 Cr Ignition.
    Ignition, Owners Manual setting
    PWK 38AS
    JD Blue Needle #4 position
    Main 185
    Pilot 48
    Slide #7
    Air Screw 1 1/2 turns out
    Powervalve Stock/Walts Silver Spring 3/4 way up.
    Amsoil Dominator 40:1
    Fuel 97/Octane Booster
    Stock Pipe/Stock Silencer
    No bogs, no stumbles, no flat spots, runs great revs fast. This carb did not work with my WR Ignition.
    I also got the 06 WR125 Dialed in today.
    06 Wr 125
    Wr Ignition, Retarded it 2 Degrees From Owners Manual
    New 09 Cylinder/09 Powervalves
    Carb Older TMX
    Carb Dividers Front And Rear
    Slide 3.0
    Needle # 59 #4 Position
    Main 460
    Pilot 40
    Dynoport Pipe
    FMF TC II Silencer
    Powervalve 3/4 Way Up with Stock and Walt's Siver Spring
    Bike stands straight up in the air in 1st thru 3rd gears! It just totally rips 1st thru 6th! All I can say is it has one heck of a powerband! The bike also runs this good with the PWK 38 AS on it as well. I think it has a little more bottom end with the dividers in the TMX.
    I started at 7am this morning and have tried about every carb and jetting combo possible on both bikes and even moved timing.
  11. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    Why did you retard the timing on the '06?
    GP
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Was trying to see if I could get an ounce more of low end without affecting the top too much. At first I advanced it about a degree at a time then came back and tried retarding it. Seemed to work good.
    Up dates:
    I had time today to dig out an FMF Fatty pipe that came with the 06. First I heated all the dents and blew them out. Then I took the rear pipe bracket off and cut the stinger off. I fitted the pipe, heated the head pipe a little to pull the pipe a little away from the radiator hose. I then cut the stinger and rewelded it back on. I also welded the rear bracket back on, since it had to be relocated for the 09. The finish on it was pretty rusty so I just sandblasted the whole pipe and sprayed it black. I taped off around the FMF logo and left it shiny. Looks pretty good.
    All I can say is that the 09 Wr 125, Cr Ignition, PWK 38, FMF Fatty Pipe and some in house porting and polishing has made this thing one heck of a ride![IMG][IMG][IMG][IMG][IMG][IMG][IMG][IMG][IMG][IMG] Out of a scale of 10 Thumbs up, I give it a 10. I have had alot of 125's in my lifetime and this has been the best one after these mods.
    rockdancer likes this.
  13. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    you guys are crazy - but I love it[IMG]
  14. tommytwostroke Husqvarna
    Pemberton, B.C. Canada
    2010 WR125, 2017 TX300
    I wish I could work on huskies all day and every day! Gettin' paid for it is the hard part.
    Just jealous!
  15. wallybean Mini-Sponsor
    Montana
    Paid? I just do it for the enjoyment of tinkering with the bikes we love. If you had to make a living doing it it wouldn't be as enjoyable.
  16. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    Some of us are fans and some are Fanatics...and then there's Darty...[IMG]...
    Tough to keep up with that man...
    If you are interested; and I know you are...
    We have some closure on the modification outcome...Check "Andy's Report'' over in racing.
  17. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Awesome, Pat yourself on the back for dialing that one in and congrats to Andy! Am pretty darn proud of you guys!
    Are you guys gonna run the one in Gosport, IN (Close to Indianapolis, in May)? My son and I are going to watch that one. Ask Andy if he needs for me to bring a spare # plate?
