The Husqvarna TR650 Does Not Exist
Discussion in 'TR650' started by mag00, Sep 4, 2013.
  1. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    I found this article, but do not know the original source. It seems to be copy pasted all over the net. Can anybody find the real source, and what do you think about adding it to wiki?
    All-new dual-purpose platform joins Husqvarna's 2013 line
    July 11, 2012
    The following is an industry press release...
    Husqvarna TR650 Strada
    Husqvarna TR650 Terra
    Husqvarna Motorcycles is an international manufacturer of off-road and on-road motorbikes. It was originally founded in Sweden and has been part of the BMW Group since 2007. Since this time, the innovative technological capabilities of Husqvarna Motorcycles have been dynamically strengthened, and on a lasting basis, through its alliance with BMW Motorrad.
    The motorcycle brand with the Scandinavian roots, based today in Cassinetta di Biandronno in the northern Italian province of Varese, boasts a tradition of motorcycle manufacturing which stretches back more than 100 years, making Husqvarnas the oldest motorcycles in the world with an uninterrupted production record. In ten decades of company history, Husqvarna Motorcycles has been able to achieve outstanding success in international off-road racing, with 82 World Championship titles to its name to date. In road racing, Husqvarna was successful in the 1920s and 1930s, so it was a logical step to set about expanding today's product range in the on-road arena once again.
    Husqvarna re-entered the road bike segment in 2011 with the presentation of the Husqvarna Nuda 900 and Husqvarna Nuda 900 R models. These models, developed in collaboration with BMW Motorrad, likewise display Husqvarna's typical pure, athletic and dynamic styling. The brand most recently provided a look ahead to further extension of the model range with the Husqvarna Concept MOAB, Husqvarna Concept Strada and Husqvarna Concept BAJA studies.
    With the new Husqvarna TR 650 Strada and TR 650 Terra, Husqvarna Motorcycles continues its model offensive that began last year with the successful launch of its road models.
    Husqvarna TR 650 Strada and TR 650 Terra – two powerful characters for on-road and off-road riding.
    With the new TR 650 Strada and the new TR 650 Terra, Husqvarna Motorcycles extends its program of highly agile, dynamic single-cylinder motorcycles by adding two attractive new machines.
    Their slim, wiry stature and masculine, dynamic design gives the new Husqvarna TR 650 models a progressive, light and energetic look, whether as the "Terra" version for light terrain or as the "Strada" version for asphalt-based motorcycling fun. At the same time, the two new Husqvarna models are clearly set apart from their competitors with their outstanding overall package of handling and riding dynamics as well as in terms of design. Along with their relatively low weight, a powerful single-cylinder engine and an agile, directionally-stable chassis they embody the passion of motorcycling and the fascinating world of Husqvarna Motorcycles.
    Outstandingly powerful single-cylinder engine in the BMW Motorrad mould.
    In terms of engine technology, the TR 650 Strada and TR 650 Terra rely on the tried and tested basis of the G 650 GS by BMW Motorrad. However, this liquid-cooled single-cylinder power unit with two overhead camshafts and 652 cc was extensively modified and its performance significantly enhanced for use in the two new Husqvarna models. It delivers 43 kW (58 hp) at 7,250 rpm, developing its maximum torque of 60 Nm at 5,750 rpm. For those countries with graduated licencing, there is also there is also a reduced power version on offer as an ex works option with 35 kW (48 hp) at 7,250 rpm and 54 Nm of torque at 5,750 rpm.
    The single-cylinder engine has been modified with a wide range of measures to hone it for its athletic, dynamic purpose. In addition to various other improvements, such features as a modified electronic fuel-injection system, altered camshafts and an increased compression ratio due to modified piston and cylinder head geometries ensure powerful propulsion, high revving and spontaneous response. Nonetheless, with its exhaust system in stainless steel including two rear silencers and a closed-loop 3-way catalytic converter, the engine provides not just an especially high level of single-cylinder riding fun but also excellent fuel efficiency and environmental compatibility.
    In conjunction with the constant-mesh 5-speed gearbox, the powerful and high-revving single-cylinder engine in the Husqvarna TR 650 Strada puts in an especially impressive performance on country roads, while a full torque curve and spontaneous response also allow supreme off-road excursions over light terrain on the TR 650 Terra.
    Robust, high-quality chassis for riding fun both on and off the road.
    The new Husqvarna models TR 650 Strada and TR 650 Terra are able to rely on an agile chassis based on a split-backbone tubular steel frame with remove-able rear frame and front beam bolted to the engine.
    Front guidance and suspension duties are dealt with by a torsionally-stiff 46 millimetre upside-down telescopic fork. The rear wheel is controlled by a torsionally-stiff dual swing arm made of pentagonal steel tubing in conjunction with a centrally-mounted rear shock with progressive linkage. In keeping with its use on asphalted roads, the Husqvarna TR 650 Strada has cast wheels made of aluminium while the TR 650 Terra reflects its off-road suitability with a centrally-mounted rear shock with progressive linkage. Generous suspension travel of 190 millimetres at the front and rear makes for easy handling and a high level of directional stability combined with excellent comfort and off-road qualities.
    TR 650 Strada fitted as standard with ABS. TR 650 Terra with ABS as an optional feature.
    To match the dynamic performance available, the brake system consists of a single-disc brake at front and rear which offers supremely solid stopping power. The new Husqvarna TR 650 Strada is fitted as standard with ABS, while the new Husqvarna TR 650 Terra can likewise feature ABS if this is ordered as an ex works option. The ABS is disengageable for special uses.
    Masculine shaping in dynamic, Italian design.
    To reflect their high level of riding dynamics, the lines of the new Husqvarna TR 650 Strada and TR 650 Terra have been given a particular dynamic emphasis in terms of design. Although they embody masculine athleticism, their clearly-defined shaping nonetheless conveys a sense of agility and lightness. While the light-alloy cast wheels in the TR 650 Strada embody the active riding character of a road bike, the spoke wheels combined with a high fender on the front wheel reveal the dual sport ambitions of the TR 650 Terra.
    The two new Husqvarna models have a robust, masculine appearance through selective use of black-coated chassis elements such as frame and swingarm. In addition, red side trim elements for the TR 650 Terra, and a black side panel for the TR 650 Strada, in combination with the Strada’s low white front fender, lend a unique appearance to each.
    The bikes' high aspirations in terms of riding dynamics are underscored by the light-gray sand-cast engine cases, providing a fascinating technical contrast in conjunction with the hallmark Husqvarna red cylinder head. Further accents are provided the anodized-silver upside-down forks and the end caps of the twin exhausts, which proudly exhibit the Husqvarna logo.
    The new Husqvarna TR 650 Strada and TR 650 Terra are manufactured at the Husqvarna Motorcycles plant in Cassinetta di Biandronno, northern Italy.
    An overview of the key features of the new Husqvarna TR 650 Strada and TR 650 Terra:
    • Powerful, high-revving single-cylinder engine with a 652 cc capacity.
    • Output 43 kW (58 hp) at 7,250 rpm and maximum torque of 60 Nm at 5,750 rpm.
    • Output version 35 kW (48 hp) at 7,250 rpm and maximum torque of
      54 Nm at 5,750 rpm as an ex works option for those countries offering graduated licences.
    • TR 650 Strada, unladen weight: 168 kg (370.37 lbs) / weight fully fuelled: 186 kg (410.06 lbs). (US-Version: 374.78 lbs / 414.47 lbs)
    • TR 650 Terra, unladen weight: 166 kg (365.96 lbs) / weight fully fuelled: 184 kg (405.65 lbs). (US-Version n.a.)
    • TR 650 Terra without ABS, unladen weight: 165 kg (363,76 lbs) / weight fully fuelled: 183 kg (403.44 lbs). (US-Version: 368.17 lbs / 410.06 lbs)
    • Handling-oriented, robust chassis concept with split-backbone frame and swing arm made of steel as well as telescopic fork and rear shock with linkage (suspension travel at front and rear 190 mm / 7.5”).
    • Light alloy cast wheels in finely wrought 10-spoke design for the
      TR 650 Strada and characteristic off-road spoke wheels with light-alloy rims and hubs for the TR650 Terra.
    • Highly stable brake system with single disc brake front and rear and ABS (as standard in the TR 650 Strada, ex works option for the
      TR 650 Terra).
    • Masculine design with dynamically-shaped body panels.
    • Fuel tank placed to optimise centre of gravity for enhanced handling.
    • Options and special accessories: ABS (TR 650 Terra only), power reduction to 35 kW (48 hp), windshield, hand protectors, low seat, engine guard, heated grips, alarm system, rear softbag, topcase, side pannier.
  2. Thumpa Husqvarna
    san francisco bay area, california usa
    TR 650 Terra
    CCM Dakar, G650X
    Hmmm, how can the non abs Terra weigh more than equivalent abs model? For that matter, what makes the US Terra so much heavier period?
  3. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    Simple answer, it doesn't. The ABS model weighs 2.2 lbs more than the non-abs model.
  4. Thumpa Husqvarna
    TR 650 Terra
    CCM Dakar, G650X
    As i read it, Terra - US non ABS 410.06 lbs wet - with ABS (non US) 405.65 lbs wet. That's a chunk of change, either a typo or.... ?
  5. Thumpa Husqvarna
    TR 650 Terra
    CCM Dakar, G650X
    Or put another way, why is the US non ABS Terra a full 7lb plus heavier than it's Eu version? Wet -EU 403.44lbs vs 410.06lbs US?
  6. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    non-us versions don't have the evap cannister, and accompanying valve, hoses and hardware. there may be other emissions stuff we get saddled with too (Thanks C.A.R.B.)
  7. Thumpa Husqvarna
    TR 650 Terra
    CCM Dakar, G650X
    I'd considered that was a small part of the 7lb difference. But really can't fathom much of where the rest lies? As Eu also has pretty tight regs on emissions, cats and so on. So it got me kind of curious.
  8. chris1261 Husqvarna
    North Jersey
    2013 TR 650 Strada
    looks like 4 1/2 lbs is dry weight, and only about 2 1/4 is wet. i guess the US bikes hold more fluid somewhere? (blinker fluid!)
    Scutler and Thumpa like this.
  9. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Update on the wiki, somebody has been busy
  10. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    I updated that page with the infobox and image in late '13 to give it the same appearance as other wiki pages.
    I don't think it's changed much since.
  11. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Last time I looked, I think it was about half the size. It looks like it needs some tweaking. Might be a good place to make reference to airbox and stalling, who knows, maybe Husky will be shamed into doing something.
    An entry such as
    Inherent problems: Airbox does not seal out dirt and bike will randomly stall when taking off in front of traffic. Husqvarna will not address these issues.
    Talk about giving them a black eye :thinking:
    Now that I think of the negative publicity, it couldn't hurt to put BMW management on this too. After all, it did happen under the BMW ownership.
    A boondoggle of a design, produced under the BMW watch , that BMW walked away from by selling off Husqvarna.
  12. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    Weight difference could be the 17/18" rear wheel difference. Rubber weighs a LOT and the wheel would be a bit heavier.
    mag00 likes this.
  13. nev.. Terrarist
    '13 TR650 Terra
    '14 XT1200ZE
    Wikipedia isn't intended as a place to vent your frustration or anger. I don't think it is an appropriate place to bring up such issues. Have a look at other wiki pages for specific vehicle models and see if similar issues are dealt with on their wiki pages. Wikipedia is not the place to 'shame' or complain. All wikipedia articles must be written with a neutral point of view and based on citable evidence or the bias or uncited claims will be removed.
    https://en.wikipedia.org/wiki/Wikipedia:Neutral_point_of_view
    As for BMW... let it go. It is not their problem.
    Husqvarna is a legal entity on it's own. BMW sold it. Any resolution must come from the new owner. If you sell a car with a hole in the muffler, the new owner owns that muffler, and the hole, and the legal burden to fix it is on them not on you.
    Ignaciob likes this.
  14. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Everybody gets a gold star :eek:
    That is kind of a mean spirited response you posted eh?
  15. krider59 Husqvarna
    eastern pa
    trt 650 terra
    02 k12rs 05k12lt
    ugh im gonna TRY to sell mine before its to late.
    mag00 likes this.
  16. vodka Husqvarna
    South Australia
    TR650 Terra ABS
    R1200R , Yamy WR250R
    Its too late................ You have established a link with a machine..nay a concept where you are defined not by your riding of such machine but by the intensity of your problem solving capacity.
    You are to rejoice in the opportunity that fate has placed upon you..for it is within these achievements that you will truly find self value create self esteem and be happy.....
    tweber, mag00 and hasenpfeffer like this.
  17. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    Vodka,
    It isn't a VW beetle you know...or an early Ducati. There exists no succubis in the machine.
  18. krider59 Husqvarna
    eastern pa
    trt 650 terra
    02 k12rs 05k12lt
    getting rid of 2 boat anchors at once, trading the terra and 02 k1200 RS on a new KTM 1190 adv r. Getting rid of the RS before the the final drives fails and the terra be anything goes wrong. In 2 years there will be no parts for it.
  19. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Anybody been following the wiki progress? Bumpity bump
  20. Norman Foley Husqvarna
    I still love K bike guys telling me about no chain maintenance and then the day of reckoning comes...... I'm glad to buy chains and sprockets!
    Scott Jones likes this.
