mag00
My fault, I edited the bike from a drz400 to a dr650 for those very reasons you just mentioned Glitch. The 400 is better in every way. But it's only the big lazy singles that truly suit. Tenere, KLR, DR and I wonder now maybe what the specs are of KTM's old 640.
For all the reasons you've mentioned 27rich is why I have a TR. I'm just learning now about how and why these other slow poke thumper bikes still exist, why they haven't been hotted up and why they will continue to be produced.
So a G650GS top end ey?
Hmmmmm...
Thumpa, I am considering the base gasket options for sure, but doing so would change the valve timing. A g650 piston has a chance.
A g650 piston will have to weigh the same as the one you pull. Crank is lighter and balanced for the high performance piston. With the higher lift cam, the piston will still need the reliefs for the valves.
Maybe you could just put a thick head gasket in?
