Theory On Our "Stalling/Stumbling" Issue
Discussion in 'TR650' started by MotocycleWriter, Jul 30, 2015.
  1. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    ok, I dont have one, whats its hooked up to?
  2. MotocycleWriter Husqvarna
    North Alabama
    TR 650, TE 250
    BMW R1150RT, BMW R100GS
    So it's just emissions crap? If so, can it be cut out of the loop without any effect on performance later? Will it alter the way the ECU learns?
    This begs another question: Do bikes from countries that don't require the canister experience these problems? If so then could we be looking at multiple potential problems, which is making a solution harder to find.
    If all the fuel wasted from poorly running vehicles as a result of pollution control equipment since 1970 were added up it would probably amount to 20% of all the fuel burned in that time.
  3. Scott Jones Husqvarna
    western Finger Lakes, New York
    2013 TR650 Terra
    1995 Kawasaki KLR 250 2016 Beta XT
    I don't think I have one either, unless it got gone when the evap canister was removed.
  4. WayneC Husqvarna
    Sydney
    F650GS Dakar
    The tank vent valve is only on the US models and it is included in both the fault monitoring and diagnostics tests for engine ECU's. Same deal with the BMW Rotax models. If you check the testing results from DRZCharlie they show it pulsing and also the injector timing being reduced when it is open to the inlet. When removing it it would seem you would need to also reprogram the BMS-E to ECE firmware to stop the reduction in injector timing when the BMS-C believes it is active
    engineerk9 likes this.
  5. hasenpfeffer Husqvarna
    CO
    Yes, it can be removed with no ill effects. Many, many people have. I have left my emissions systems in place, with no ill effects. It has been shown to be a potential problem in the past. As with most of this TR, YMMV.
  6. Mark_H Husqvarna
    Lapu Lapu Cebu Philippines
    Thank you for the info and scope shots, very interesting.
    The Purge Valve on the bike in the video was faulty and leaking air in creating a 'lean condition' not a rich one.
    Plugging the hose between throttle body and valve completely cured the crappy running and 'random' stalling issues.
    My theory is that this is occurring on more than one bike and could be the cause of the stumbles, but I need to test it a little more.
    On my bike there is no cannister but I still have the valve so I will use it to test the theory that the bike stumbles when the valve is in operation.
  7. big-t Husqvarna
    tr650
    ktm,yamaha
    You could be on to something here,but without a poor running bike and some test equipment its hard to verify.
    Actually,I think since there is no Mass airflow on this bike to meter the airflow entering the engine the actual lean condition comes from the fact that all available fumes have been sucked from the cannister and the leaking purge valve is allowing pure air to be pulled thru the cannister and into the engine,which the o2 immediately reports to the ecm and it responds by going full rich to compensate for high o2 and causing crappy running.All theory of course...:)
    I Here is a graph from my LM2 while I was pinching and releasing the purge hose.You can see how much effect it has on the fueling
  8. Roger 04 RT Husqvarna
    TR650 (friend's)
    2004 BMW R1150RT
    Hi big-t, Good chart. It looks like the rpm dips when you pinch the hose. The AFR on the Terra is not that well controlled by the ECU but I don't see any signs that it goes full rich.
  9. big-t Husqvarna
    tr650
    ktm,yamaha
    Roger that was just some speculation on the leaking purge valve issue posted by Mark_h
  10. Roger 04 RT Husqvarna
    TR650 (friend's)
    2004 BMW R1150RT
    Got it, and thanks for posting the chart. It's always great to have actual data to discuss.
  11. wade171 Husqvarna
    650 strada
    no
    Does the purse hose work mind got some serious porblems below 3000rpm
