timing
Discussion in 'Vintage/Left Kickers' started by Bigbill, May 15, 2015.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    http://www.dragonfly75.com/motorbike/timingcurves.html here is a good read about advancing/retarding timing. contains exerpts from eric gorrs book, whom i think we can all agree is a master of all things 2 stroke.
    SteveJ likes this.
  2. Bigbill Husqvarna
    '83 250wr
    0 right now
    Regarding the timing is better I guess. This means the increase in power will be even better?
    i usually retard timing some from huskies specs, and it always helps them pull smoother into the top end, altho it gives up a bit of bottom/mid response sometimes.. less or no kickback and easier starting however makes the slight loss of snap acceptable to me. the engine being more willing to wind out is just a bonus.all engines are different, you have to play with it, just like jetting. i have ran every size of 80s husky 250 and up except for 430 until now, so im playing around with one currently. the book calls for the 2.3mm btdc with the external mini 6 plat, but im at about 1.4mm right now with no loss of power that i can tell yet and there is no kickback. pulls smoother as well..im playing with the vm and its close but i hope to have a lectron ordered for it soon.
    a modern electronic ignition would fix this as it would retard the timing to zero for starting and idle, advance it harder for high load/wot midrange, then steadily retard it towards the topend as rpms increase....giving us the best of everything.
  4. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    My 83 500CR is set at 2.8, pretty hard hit in mid range. I think I will try the 2.2 mm setting and see if it makes the power delivery smoother.
  5. justintendo klotz super techniplate junkie
    i would be very surprised if it didnt, likely start easier too. you still have the internal motoplat on the beast?
  6. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    my 82 500 is at 2.2 its already pretty hairy hit . actually wouldnt want more . i still dont get full throttle many times during a lap . but when i do it will pass anything ive lined up
  7. Kartwheel68 Husqvarna
    Newnan, Georgia
    Advancing timing DOES NOT increase RPM, all other things being equal it will make an engine hit harder in the middle and taper off on top. Retarding timing will make an engine softer in the middle but pull longer on top. For someone who pontificates about engine tuning all the time, bigbill rarely actually gets any of it right.
  8. SteveJ Husqvarna
    New Mexico
    Justintendo, Yes, still the internal rotor Motoplat
    SilverstreakNZ, Still learning to ride the animal, It's my latest bike. Only got to race it once (vintage MX) last season. Picked myself up out of the dirt several times.
    Thanks for the advice guys. I'll try the 2.2 mm timing and see what I think.
  9. justintendo klotz super techniplate junkie
    nice thing about that internal motoplat is the ease of adjustment, all screws are exposed. play around with it. i would try to get it retarded some and see if theres a loss of power anywhere vs. smoothness and starting..does it ever kick at you starting?
  10. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    I have 2 settings marked on the flywheel of my 349 Cota . One about 2.5mm BTDC is for softer delivery while the 2.0mm BTDC is for more professional delivery(more aggressive)
  11. SteveJ Husqvarna
    New Mexico
    It is funny how the obvious sometimes eludes me :banghead: . You are right, TDC does not matter when using a timing gauge (as pointed out by Fran and Silverstreak). I've spent my life in automotive service and am so accustomed to the idea of using degrees BTDC (before top dead center). That same automotive experience would have led me to believe that more RPMs require more timing, a wrong assumption in two stroke land.
    SilvertreakNZ: I set the 500's timing to 2.2mm this evening after work (backed off from 2.8mm). Didn't have time to ride it yet. I suspect that the real test will be on a track at the next vintage MX I attend.
    I'll give some feedback on the results as soon as I can.
    Justintendo: haven't experienced much kickback when starting this bike, just once I can remember. Never have experimented with timing on two strokes, so I'll take your advice and play with it some.
    Learning from everyone here, thanks for starting the thread Bigbill.
  12. Bigbill Husqvarna
    '83 250wr
    0 right now
    I'm still learning some things too.
  13. Arthur Smith Husqvarna
    1972 250 WR
    What are the specs on the case bolts on a '72 250 WR? Looking for example only: bolt's diameter is 8mm with a pitch of 1.25 and a length of 25mm.
    The bolt size is a M8-1.25x25, I'd like to change mine out to some allen heads.
  14. jimspac Husqvarna
    Connecticut
    You may be able to get a complete engine set from DC Plastics. They have several sets for most Husqvarnas.
