I've been thinking about this, and there seems to be 2 issues. First, there's the problem of the bars creeping up during day to day use. The set-screw or the bead of weld would take care of that. What worries me, is what happens in the event of a tip-over. I would be afraid that the brackets may be able to jump over the bead, or set-screw and still manage to damage the exhaust or not fully protect the bike. I think the idea of the bracket that works as a sleeve and hooks into the frame would be the most secure in the event of a crash. (providing it was stout enough) and isn't that why you would put these things on your bike to begin with? Just my $0.02 --Chris
so if youre going to weld a bead, why not just weld them on with like a tiny little weld? then it could break if you crash TOO hard, but hold if it's not a super hard crash.
I would want my crash bars removable for maintenance. But you could drill through both the AdvRider bracket and the Husky brace and bolt them together. Looks like the flange is wide enough at the bottom to do this.
Well I did the hose clamp fix temporarily, which seems to work.. Although it does not appear to be sufficient for a crash situation.. Hoping for a good permanent solution soon, like before a crash....
It is now next week. 4 parts went out, and I have received 100% positive feedback on all 4. More updates later, but just wanted everyone to know this is actively being worked on.
"Is this a fix from Alt...or is it something we have to purchase from someone else?" And can I get it installed before my trip next weekend?
I believe it is a permanent fix from Alt. We should have an official word from them very shortly... Just have a little more patience.
FWIW, I used my Altrider crash bars for their intended purpose: crashing. I took a low speed but focused impact to the left side by a big rock. My radiator would've been toast without them. The bars did creep up and touch the header pipe, but there is no damage to the pipe at all. I too would like to see a better solution to the creeping issue, but it's not as dramatic of an issue as some are making it out to be IMHO.
My bars have been on for almost 3000 miles, much of it rough, and they have not moved. They would if I went down though. Looking forward to the fix.
Mine moved during normal use. Used the hose clamp for a temporary fix. If altrider doesn't come up with a good solution I'll solve it myself this winter.
OK, a fix is available through ALTRider, here is more information and how to order: http://www.cafehusky.com/threads/altrider-crash-bar-supplemental-part-will-be-available.35767/
Good job Coffee, and thanks for your help and patience. This looks to be a good fix and I expect it will work out just fine.
I'm happy to see AltRider come through with a real solution. I have to admit, I was losing faith in them really quickly.
