No it is not stiffer nor softer, it is the same. I can not compare with a lowering link, for me the lowering ring works fine. Regards, John
If I get how the lowering ring works ( I haven't seen one actually installed but it looks like all it does is rteduce the preload) the ride HAS to be softer. Now mostly shorter people are also lighter so it may get them back to where it needs to be in terms of intiial travel but the spring rate will still be the same only the initial break free load will be lower. If the rider is short ( legged) and heavy , the preload will be very soft and the bike will be already a fair way into its travel. Bike will wallow a fair bit and bottom easier ( as Sally's ktm is currently until I can get the Kouba link that I finally got, mounted ).
Yup, same here (~29" inseam). It seems like I'm tippy toe on dang near every bike, 'cept cruisers........ but I just can't go there.
Same 29" inseam here too. Been following this thread to decide which way to go to lower the Terra and retain the SWMotech center stand. It's very difficult, not to mention dangerous, to tippy toe in Manila traffic.
Totally flat foot. But I stick to the pavement. Don't know what an off camber trail would be like but the bike isn't top heavy anyway
Shock Treatment lowered my Terra, OEM spring rate is 10.3 kgs, new spring was 10mm shorter & 9.8 kgs, what a difference it made, vast improvement
This is a little unconventional but it's been a great help and I feel even better on this bike: There's a quality cobbler near me. I had them put a more rugged vibram sole on the bottoms of my "adventure" boots - AND I had them add an inch of lightweight but very firm FOAM filler between the bottom and my foot (don't know what that part of a shoe is called!) Anyway, I really got a great lift from it, no change in shifting or breaking, no balance issues, any extra weight is hardly noticable. Any good shoe repair should be able to do this for you. And there are different thicknesses, if you only want 1/2 inch I'm sure it will still make a difference. The cobbler told me he's seen a few motorcyclists coming in for the lift lately. LOVE the difference. ...and no, it doesn't look completely dorky...... just a little bit.
Just installed Seat Concept's LOW version seat on my Terra last night. The relative height difference in the "butt" area appears to be around 1/2" and the new seat profile provides a deeper pocket for the rider. (I also measured drop in the lowest, narrow area of the seat and it is a tad less than 1/2"... sorry no pics of that). The new cover floats above the foam in this area so there is more drop than shows in the picture.... maybe another 1/4". View attachment 54161 View attachment 54162 View attachment 54164
I would appreciate any for sale ads would be put into the classifieds and not in threads like this...
