sorry about reviving an old thread but I am about to do the same thing on a '09 610. Does anyone know if the instrument plug is the same in terms of which pins are which?
+1 on that last post. And can you mount it to the oem bracket or do you need to buy the mounting hardware to?
I'm just in the process of installing one of these and I'm trying to remove the original speedo cable from the calliper. Can't seem to get it out. Any ideas?
It just screwed out for me. However, I used the original cable. It has the same plug at the top, so there is no need to chage cables.
Question regarding the LED bulbs vs incandesent that were provided in the dash pod.. when i try to fit the LEDs in the housing, i am having trouble.. any ideas/help would be appreciated.
Doubt that anyone will respond to this but, when you installed your trail tech. Did you wire up the factory wheel speed sensor or did you use the new provided sensor.
