All 2st Transmission Oil
Discussion in '2 Stroke' started by Bill502, Feb 10, 2011.
  1. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Oil capacity: 0.70 litres (0.05 quarts)
  2. Toro618 Husqvarna
    wr125
    I just changed the oil yesterday.....I put 750cc and that's just above the 1/2 mark on the sight glass. So the exact is probably more like 725cc.
  3. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I run Walmart ATF Type F. I didn't have enough on one oil change so I used Rotella T since I had some in the garage. It had more clutch drag and I hit a lot of false neutrals. Went back to ATF and it works great.
  4. Toro618 Husqvarna
    wr125
    I use Bel Ray gear saver 75w.....works well for me
  5. john01 Husqvarna
    Powhatan VA
    Rotella white jug (15w-40) here too. We have 6 dirt bikes and they all run with it. Two of them have the Rekluse EXP's and no problems with any of them to date. It's cheap so we change them often.
  6. MMMOTORCYCLE Husqvarna
    Whats the difference between 10w40 transmission oil and 4stroke 10w40 engine oil (ie Mobil 1)?
  7. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Since this old thread started I've switched to using Rotella 15w40. It's the equivalent of 50w gear oil. Pretty much any motor oil that is JASO rated will work with a wet clutch in a 2t. I looked up the ATF +4 and the gear oil rating was only about 25w so I thought it better to go to something a little heavier.
  8. MMMOTORCYCLE Husqvarna
    Am I going to hurt anything using a 4stroke synthetic like Mobil1?
  9. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    ATF type F here.
  10. NephronRacing Husqvarna
    Minneapolis, MN
    2002 CR250
    '98 Ducati 748, '69 Honda CB350 Cafe
    Motorex RACING PRO 4T 0w40
    Tinken likes this.
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    only ya wallet! :)
    ohmygewd likes this.
  12. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Unless newer models are different to 09
    .8 Litre
    800 mil
    Transmission oil .................0.7 Imp. Quarts
    Olio nel basamento............................l 0,8
    Ive been using 10w 50 car motor oil
    I use a 1 litre tomato sauce container from Kmart which has measurement on sides - squirt in in filler hole
    easy way to measure it and dont need funnel
    steadydirt and jaxsplatt like this.
  13. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    No, as long as you do not use the Mobil1 0w50 Racing or the 0w30 Racing. Those two Mobil1 oils are off limits for use in motorcycles. Check the specs of Mobil1 against Motorex, you will find that they are identical. This is because Motorex often purchases it's base stocks from Exxon.
    p.s. buy your Mobil1 @ walmart so it doesn't hurt your wallet...;)
  14. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    http://www.bikez.com/motorcycles/husqvarna_wr125_2012.php
  15. rockdancer Husqvarna
  16. NephronRacing Husqvarna
    Minneapolis, MN
    2002 CR250
    Base oil is base oil, regardless of source. Motorex is not Mobil1 repackaged. I work with the Motorex USA guys.
  17. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Just drained mine into the measuring jug I use for my gear oil after makeing sure the oil was smack on dead center of the sight glass and exactly 700cc cam out!
    Refilled with 800cc and its over the sight glass nearly all bar a mill !!!
    Think my jug is due for calibration :lol:
  18. rockdancer Husqvarna
    Mine has a small screw - no sight glass. Did you check it with a warm motor? There will always be some oil left around the place so 800 mil is from new/ dry I guess
  19. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Stone cold but it was left to drain all day - The jug I use is a real cheap buy one get ten free type so may be well out if the truth be told and out of curiousity Im going to see how close it is, I would say the manual is correct and stand corrected :thumbsup:
  20. rancero86 Husqvarna
    SE Michigan
    Anyone using Joe Gibbs MX1 oil?
