Two new offroad 250F's from Yamaha for 2015
Discussion in 'Non-Husqvarna Motorcycles' started by woodsrider, Oct 16, 2014.
  1. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    Would you really choose to go back to a cable after having a hydraulic clutch? I don't think you would. :D
    I hear what you're saying about reliability, most of my mates that have had Magura clutches have had leaks. The Brembo one on the TE has been great, I haven't had to touch it & I can ride one finger on it all day.
    Definately felt a full day on my WR450F cable clutch though.
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Actually they don't bother me. The TE is the first bike I've ever had with a hydraulic clutch. Guess I'm a little bit old school on that. Do I like it? yup. Do I want it to leak on the middle of nowhere? Nope
  3. JMP1899 Husqvarna
    Yamaha WRF
    If the cable clutch is soft it's OK, but I prefer hidraulically because always works soft & I never have had any problem...
    The diferent weight between Mx & Enduro is 12kg, too much. Yzf 250 is light 99 kg dry, but the work to adapt the bike to Enduro is not so good.
    And what do you think about the position of the Enduro muffler?....
    Centerline likes this.
  4. Dangermouse449 Husqvarna
    2011 TE449
    The TE is my first hydraulic clutch as well.
    Even if I buy a bike with a cable next it'll be getting a retro fit to hydraulics, not a deal breaker for me.
    I've broken a cable before too, but no clutch isn't the end of the ride, just a challenge to get home.
    All good :)
  5. Dangermouse449 Husqvarna
    2011 TE449
    You're right!
    The increase is a massive 13kg, from 105 wet YZF to 118 wet WR off the Euro website specs.
    What did they do, fill the frame tubes with cement?:eek: That is a hell of a lot of extra lights & wiring.
    So where is it all?
    Bigger alternator, battery, starter & gears, lights, likely heavier(quieter) muffler, radiator overflow tank?.....
    Doesn't add up to me, I reckon that should be 8-10kg tops.
    JMP1899 and Centerline like this.
  6. Motosportz CH Sponsor
    Yep that always happens. Thats why I bought my YZ250 over the WR250 at the time (03) That stuff does add up quick and lots of little brackets and stuff. Crazy. The europeans, especially KTM, have mastered getting all the off road stuff on there and keeping weight down. Years of refinement. So then the choice is always MX bike without stuff you kinda like and needing suspension work or fat pig with the goods.
    fletchman45 and Centerline like this.
  7. Dangermouse449 Husqvarna
    2011 TE449
    I wish the MX weapons were an option in 'Nazi' controlled Australia where, in all but 2 states, we have to have full registration to ride on forrest trails...... sigh.
    Sherco 450 looks nice still, 109kg dry.... :D
    Their 250 enduro is 102KG, less than the YZ250 by 5kg & less than their own 2st.
    Euros for the win!!
    john01 likes this.
  8. JMP1899 Husqvarna
    Yamaha WRF
    Sherco 250i-300i 4stroke real dry weight is about 107 - 108kg...
    450i will be more or less 111kg...
    Also Yamaha is more more reliable...
  9. JMP1899 Husqvarna
    Yamaha WRF
    Yes, Ktm only needs about 8 kg to get all enduro components... here there is the 5kg diference... Yamaha get's enduro components without thinking in competition...
  10. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    There are always weight savings on Japanese dirt/Enduro bikes from my experience. The rock solid long term durability synonymous with Yamaha engines is notable IMHO.
    shrubitup and Motosportz like this.
  11. Dangermouse449 Husqvarna
    2011 TE449
    The five valve Yamaha in 450cc guise is nuclear proof, no question there!
    I flogged my '05 around the forrest over here for 185 trouble-free hrs before selling it for the TE449.
    It will be interesting to see how the new 4valve reverse cyl eninge is in an enduro for life, hopefully as good.
    The lighter TE is as reliable with no mechanical trouble in 145hrs, not even a valve reshim.
    Time will tell with the brand new Sherco 450 engine as it isn't released yet.
    It looks increasingly likely I'll end up on one so might be able to let you know first hand.
  12. JMP1899 Husqvarna
    Yamaha WRF
    Yamaha is the best in durability...
    Hva 449 is reliable too, but sherco 250-300 4s... not so much... not big problems but is not his best.
    Sherco 450 will see...
  13. JMP1899 Husqvarna
    Yamaha WRF
    The position of the muffler of yzf & fx is one of it's best innovations... but in enduro wrf, Yamaha don't respect this position & waste this innovation. ..
    I really don't like it...
  14. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Looks like the WR's have the muffler mounted higher for better water crossing clearance IMO.
  15. JMP1899 Husqvarna
    Yamaha WRF
    For a better wading depth the most important is admision (height of air filter) ... If the engine is running the water don't enter throught the muffler...
    Yamaha wrf have a good wading depth because of the good position of the air filter...
  16. Russ Henry Husqvarna
    Seattle Washington
    2013 TXC 310
    I am surprised they are not offering a offroad version of the YZ 250
    When are the new 250f's available ?
  17. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    YES! A 6 speed trans, Estart, open chamber KYB's and a side stand would be awesome. Somebody pinch me, I must be dreaming...:D
    fletchman45 likes this.
  18. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    18" rear wheel, bar mounted map switch(to keep up with the cool kids) & a bigger tank too. make the estart a proper estart or otherwise optional. throw in a hydro clutch to seal the deal! sign me up right now:p
  19. fletchman45 Husqvarna
    park rapids
    Out of all the Japanese bikes I've ever ridden. The yzs I seem to adapt quickly to. And I've always (and to her face) compared my wife to a yz. Not the best at anything but simply good enough at everything to win the shootout!
  20. fletchman45 Husqvarna
    park rapids
    Before jumping on this KTM whoops I mean Husqvarna band wagon my wife and friends suggested I buy a new yz 250 smoker. And I almost did......
